B44.3 Worlds Edition?
#46
Really hope they go for a new chassis to go with the new 2wd cars. Metric and light. And above all. Much more easy to maintain. Time for a new car now.
#47
I keep holding off on a wheeler because I'm hoping for an AE wheeler kit update. I run tlr 2wd, but not sold on dropping over 450 on the 22-4 that is loaded with new platform issues. (I see it daily at my local tracks).
Right now Durango 410v4 or waiting on a new AE.
#52
As I understand it the .3 version will be longer than .1 but shorter than .2.
They are testing everything in between the 44.1 and plus 8 chassis to find whats best.
Momo
Momo
#53
Could anyone tell me if any of the b44 line up of buggies have interchangeable parts w the bj4 world edition.
#55
B44.2 discontinued
What's next?
B44.3 Worlds edition or B54?
Changes?
Aluminum chassis
Gear diffs
Metric
Stronger front arms
Stronger tie rod ends
What's next?
Changes?
Aluminum chassis
Gear diffs
Metric
Stronger front arms
#56
Don't HB and Xray already make better B44's?
#57
And it must be possible to close the body bether around the chassis, to keep dirt bether outside.
I don't like An Undertray to keep dirt outside.
#58
I have a 22-4 and I have to completely disagree with you that the platform is "loaded with new platform issues". The inner front hinge pins were a problem with a $6 fix. The front bulkhead seems to come in a new plastic now. The layshaft bearings should be upgraded asap as they "only last" about 20 hours of runtime before wearing down (not a flaw IMO, just as racers are throwing out the B5 and B5M stock bearings for a better quality). I recently pulled my drivetrain apart after an approximate 20 hours and the belts and pulleys still looked new. Oh - the rear axles did snap for some but that's been solved. Basically if you go buy a kit today, I don't think there are any issues. Anyway, a couple of small things but not loaded and all of the ones that I've heard about are solved.
