SC tire choice
Old 12-04-2013, 07:23 PM
wever75's Avatar
Default SC tire choice
Now that I've got my losi scte, and a set of track tires, I need a set of bashing tires ( and wheels ). I'll mainly be running on pavement. Sometimes I'll go on grass for a few minutes and some loose dirt but thats it.
wever75 is offline
Old 12-04-2013, 07:26 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
Proline has their street fighter tread, and if you want to go really onroad oriented, panther has their slick sc tire. With the proline tires you will get little no no usable traction on anything but asphalt,and maybe some hard packed dirt with no top layer. The panthers say they are designed for blue groove as well, and look to be pretty soft.
For the street though, the pro lines are great.
ThePanda is offline
Old 12-05-2013, 06:12 AM
I've read the duratrax banditos are even better than the street fighters and cheaper too.
1911kevin is offline
Old 12-05-2013, 06:26 AM
rjohn929's Avatar
Proline Trenchers are a great all arount basher tire.
rjohn929 is offline
Old 12-05-2013, 07:02 AM
1967Typhoon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by rjohn929 View Post
Proline Trenchers are a great all around basher tire.
I will agree with this 100%.
The trencher gets really good on-road traction, has enough tread depth to bite grass well, it rips in the dunes, and can do gravel and rocks pretty well also.
Where I have seen it struggle is hard packed dirt with a loose top layer. If doesn't do well at all. Everywhere else including on-road, the traction is awesome.
I see alot of people recommend the badlands as a basher tire, and it does not do nearly as well overall. It sucks on pavement, and the tread wear is terrible. You will file them down QUICKLY on pavement.
1967Typhoon is offline
Old 12-05-2013, 11:26 AM
wever75's Avatar
Trenches sound perfect, hows the tread wear? What wheels should i mount them on?
wever75 is offline
Old 12-05-2013, 11:31 AM
Wear is pretty good. I have spent about 7-10 packs on them (mostly on-road) and the lugs are all a bit rounded, but the tread depth is still fine. I got the medium compound.
As far as wheels, it doesn't really matter. The tires are a bit larger and heavier than stock, so I would stick with a plastic wheel to keep the weight down. I don't know what wheels fit your truck, but you are fine with a regular old plastic wheel from jconcepts, pro-line, etc.
