Old 07-08-2005, 05:23 AM   #1
Default bad problem unfixable ??
hi guys i got a bad issue on my hands.
i was doing the screw up that goes onto the clutch bell and it got tight and i tried to tighten it more and the screw heaps snapped off and i am left with 5mm of threaded screw left in the drive shaft of my hyper .21 engine about 2 mm beneath the top of the shaft.
any one know a way to remove this i tryed starting the engine and hoping it would turn out itself but it never.
any other ideas ??
THanks guys any help is appricated
can i buy another shaft for the hyper .21 engine ??
hyper7hyperpbs is offline   Reply With Quote
Old 07-08-2005, 06:25 AM   #2
WeatherB's Avatar
So none of the screw is sticking out?
You can always by a new crackshaft for the engine but you might as well invest in a new better engine. If you're not willing to do that, check out eBay and get yourself a used hyper .21 and swap the crankshafts.
I would try to install a new screw (with locktite) and hope that 2mm of thread going into the shaft would hold it fine.
WeatherB is offline   Reply With Quote
Old 07-08-2005, 06:47 AM   #3
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
go bu yaself an ez out kit.... they sell them at any auto part store, or sears... they work on a backwards threads principal. tap a small hole insert the die and start to thread it backwards. While ya trying to un screw it the die it getting tight and tighter on to the threads, untill it is removed....here's a link you can thank me later
still fishing
ALBERTO is offline   Reply With Quote
Old 07-08-2005, 07:09 AM   #4
the hole is ownly 3 mm though is that enough for and easy out ??
Old 07-08-2005, 07:18 AM   #5
ALBERTO's Avatar
should be i use the same kit to remove the striped screws on the bottom of my xray... thnk there the same size if not smaller.... ahhh just make sure you use the smallest one. all you need to do is just get the tip in..
still fishing
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
Problem with ESC strongville Singapore R/C Racers 3 11-29-2005 08:58 AM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
Big Problem!!1 doublest Electric On-Road 8 05-13-2003 02:01 PM
