Caster Racing S10sc Thread >
Old 11-13-2014, 04:36 PM
  #286
Originally Posted by fanfor18 View Post
Anyone have a good starting setup for a loamy, rough, outdoor track. Took my truck out using my indoor setup and I struggled to get the rear hooked up.
Hey brandon,send racecase a private message about a set-up and he can get you headed in the right direction. He may chime in on here after while.
Freddy Marsh is offline
Old 11-13-2014, 04:59 PM
  #287
Race_case's Avatar
Try lighting up your shock oil I run 42.5f and 37.5 outdoors. I also have stood my rear shocks up more straight to help traction/rut rolling. 60g in back of chassis and 28g in front. 7/7/5 diff oil is where I'm at. I have my rx8 behind the servo aswell.
Race_case is offline
Old 11-13-2014, 09:33 PM
  #288
Are you using the stock springs and pistons? I have that oil with stock pistons and springs and it was bouncing around quite a bit. I do not have the added weight which I will do. Currently I have my Toro esc behind the motor, should I move it to behind the servo? Thanks for your help.
fanfor18 is offline
Old 11-14-2014, 05:29 PM
  #289
Race_case's Avatar
I would move it if you can my truck was well balanced on corner scales, I'm running powerstrokes atm but my son is running the stage 1 shocks from caster with 3x 1/16 holes in piston
Idk about the box stock ones never used them
Old 11-17-2014, 01:13 PM
  #290
I have not seen any video's in a long time so I thought I would share this one I did a year ago or so, 1st time driving the S10SC pretty much stock.
https://www.youtube.com/watch?v=6iYQ0D5OpcY
bring it on is offline
Old 11-17-2014, 01:16 PM
  #291
And then one of my latest videos of my 2nd place finish at Amain Hobbies outback shootout...my sct is the white front, blue rear in 3rd for the 1st few minutes..
https://www.youtube.com/watch?v=unOS8JSPs_8
Old 11-25-2014, 07:04 AM
  #292
Caster Racing SCT10 4WD RTR Short Course Truck. End of the year sale! Only 1 left.
http://www.ebay.com/itm/Caster-Racin...e=STRK:MESE:IT
racer726 is offline
Old 12-09-2014, 04:59 PM
  #293
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
heres a video from the gobble stopper around thanksgiving, i tq'd with the truck and the first 5 minutes in the main the truck was good, but then i lost a front body clip that pushed the body down on one of the front tires, always making me want to go right. got 2nd in the end!
https://www.youtube.com/watch?v=1Y9SgPDHC8U
xxx-ntad2 racer is offline
Old 12-09-2014, 05:13 PM
  #294
Awesome
Old 12-09-2014, 05:17 PM
  #295
FYI.. For anyone running this truck I would suggest that on the body post that you cut the bottom little tab off and drill a hole and use a 2nd screw...
Old 12-31-2014, 10:07 AM
  #296
kinetisist's Avatar
Trader Rating: 31 (100%+)
Default race day rebuild
Just finished going through my SCT and found something very interesting.
I was having steering issues on my last race and decided to bench the truck until I could sort it out. Well I found that one of the C-hub screws was gone and the other side one was loose. I have since upgraded to the aluminum hubs as of today. While upgrading to the AL C-hubs I found that one of my front arms was crack and have a pic for you all. I was amazed that given all these issues I still had placed 5 out of 8 for the day and I am a novice driver.
kinetisist is offline
Old 01-12-2015, 10:23 AM
  #297
I will be getting my SCT10 truck together pretty soon. Full alloy pro kit with carbon fiber towers and V4 shocks. Should have it on track for a race at Washtenaw RC in Michigan. Has anyone else been racing their truck?
racer726 is offline
Old 01-12-2015, 12:13 PM
  #298
kinetisist's Avatar
Default race tires for amain clay track ?
Nice driving ... what tires where you running?
also what radio are you using .. caught a glimpse of it in the previous video?
Just finished putting all the hop parts on my SCT and took it to the track for practice and what a difference. I let my eldest son drive it and he was shocked how different/better it was to drive. I am looking forward to our next race. As for some of the setup questions I am running 5k-f 7k-c 3k-r for diff oils and shock oils are 40 fr and 35 rear for a medium size track with semi smooth outdoor packed track with loose top soil.
Old 01-13-2015, 09:59 PM
  #299
Radiopost radio that I'm selling for only $200 with 2 receivers.. I was running Panther switches clay.
Old 01-14-2015, 05:19 PM
  #300
kinetisist's Avatar
Default chassis ?
is there anyone that has a good link to a updated chassis the is not plastic?
I would like to build one that does not create a divet into the front bottom pin holder on the chassis ... or does any want to sell one they have or trade I have a lot of extra aluminum hop up parts.
