Schumacher Cougar KF!!!
#1426
I did something similar with my KF2, but I removed the brace screw holes on the motor assembly (MA) and took of the tension roller off the tranny halves thus moving the enture MA an additional 17mm rearward and fit in a 65T belt. However, I did this with a CF chassis. The forward traction was tremendous and still had tons of steering, but the CF flexed so much even with a front brace that the car was very twitchy. There was so much flex between the MA chassis I would regain a lot of the rigidity.
#1428
Schumacher does not make one to my knowledge. What you needs is a 65T, 3mm pitch, 195mm long, 4mm wide belt. I think this is what I bought:
http://shop.polybelt.com/195-3M-04-R...5-3M-04BNG.htm
#1430
yea im not gonna go that far. im going to work with the what i have.
#1431
whats a good starting point for gearing a 17.5?
thanks
thanks
#1432
This is depending what side gear and spur you are using. If you are using the side gears that came with the kit, you will have to use a 71 spur and and a 30-31 pinion. The spur that comes with the kit is to big for stock racing.
See page 33 in the manual. For a 17.5T motor, you final drive should be around 6.
#1433
#1434
is it possible to run the kf2's low grip conversion on the original kf?
#1435
All of the parts and holes in the chassis are included with the KF2 kit so you can decided to run normal or the low grip option. The manual shows how to build it for each option. The only thing not included in the kit is the ability to run the shocks on the back of the wishbones.
#1436
But there is a small shop in the UK that sells a chassis to convert a KF. Check Cobra Racing Products on FB.
#1437
#1438
anyone play around with flex with their kf? i made the rear crace a 2 part brace and that added torsional flex and the car is a little better. wondering what else i could do to add more and if anyone has done so???
#1439
Just got a kf kit and aside from missing many parts (local guy seems to enjoy raiding the boxes) the center pulley doesn't seem to be machined right. The slot where the pin sits in not deep enough to cover half the pin and the shaft has about 1/4 inch of lateral play. I looked for a replacement pulley (U4469) but it seems they are discontinued and no longer available. Is there a different part number I can use? Is the kf2 pulley compatible?
#1440
R/C Tech Elite Member
..p
