Schumacher Cougar KF!!! >
Old 02-03-2015, 08:34 PM
  #1291
Originally Posted by Tony Newland View Post
Higher holes add grip.... its so easy to type the wrong thing, I probably did at some point, wont be the first time or the last lol
Yes
laying the shocks down will add lateral grip (side grip) using the inside hole on the arms adds forward grip.... Either could fix your problem since neither of us can actually watch your car. Give both a shot and see what work in the area you need
thanks again to the both of you for putting up with my questions. one would think 20+ years in the hobby that i would retain some of this knowledge.
twisted is offline
Old 02-04-2015, 09:15 AM
  #1292
joeymdz's Avatar
Tony is spot on that these are just suggestions to to try out. Since we cant physically see your car this is the best we can do.....
Reason why I said go to the inner hole with the rear arms that you gain rear traction but will lose rotation. I did back to back comparisons and was a huge difference. Since I run mod and the way I drive I like rotation with a little slide
joeymdz is offline
Old 02-04-2015, 02:30 PM
  #1293
my biggest complaint with my set ups is the car will just spin out in the apex of a turn. it will literally swap ends. it makes it hard to drive and in return iam afraid to push it.
twisted is offline
Old 02-04-2015, 10:31 PM
  #1294
cokemaster's Avatar
Trader Rating: 18 (100%+)
I tried the car again today with proper clay tires. Not difference in lap time between my KF and B5M, so the setups seems ok. Tried the upper pin holes in the rear, but did not see much or any improvement in traction. With the pins in the upper hole, the car tends nose dive a little when jumping though.
cokemaster is offline
Old 02-05-2015, 07:59 AM
  #1295
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Sounds like its getting loose when you start to pick up the throttle? maybe add some rear toe and negative expo on your radio?
Im sure you did, but make sure to reset your ride height and camber. Shouldnt jump any different. Straight line grip probably wont change much but should add considerable side bite
Tony Newland is offline
Old 02-05-2015, 03:18 PM
  #1296
thats exactly what it does. what ive done over the past couple of days is lengthen rear camber rod,lowered pins and took a washer out from under the ballstud in the rear.
i also think i had to much camber as the tire wear is only in the middle of the tire. i was running 3* you would think i had 0* with tire wear only in the middle...
twisted is offline
Old 02-05-2015, 03:43 PM
  #1297
joeymdz's Avatar
You do know having -3 degrees of camber is too much? Whats wrong with kids these days
more camber is not a good thing.
joeymdz is offline
Old 02-05-2015, 03:50 PM
  #1298
joeymdz's Avatar
have you ever tried other setups from Petitrc? (especially from the LOW GRIP* astro turf selections?)
http://www.petitrc.com/setup/schumac...ville20140921/
Julien does really well and it might be a thing to try out.
PS~ I'm looking at your set up sheet and your tires selection seems odd to me. I've only ran on turf 1 time but with schumacher mini pins and I had way too much traction. on Julien's setup hes running a different tire combo that might just work at your track.
To me and others trying to help its frustrating trying to problem solve over the net. I know for sure if we were there it would be an easy fix.
**Does it only spin out 1 side or it doesn't matter?
joeymdz is offline
Old 02-05-2015, 05:45 PM
  #1299
oh yea i know but i appreciate your help. as for my defense on the 3* of camber... well i was at a loss so i said it cant make it any worst lol. i usually run between 1-2*
tire choice.. ill start off by saying i have bought so many tires this season its nuts. the track we run at isnt just a track. its actually just a track on sundays. then the rest of the week its a tennis court at a sports complex. so the astro turf is real turf with sand mixed in. i think the sand throws the traction out the window. so far the dboots in the rear and yellow mini spikes up front have been the best.
julians set up from Gargenville was the one i copied the most. (some of the things i could not do as i didnt have the parts)
twisted is offline
Old 02-06-2015, 08:04 AM
  #1300
Trader Rating: 71 (100%+)
Anyone have a recommendation for an aluminum servo horn in place of the Core CR192 that seems to be unavailable in the U.S.?
negatv1 is offline
Old 02-06-2015, 08:47 AM
  #1301
joeymdz's Avatar
http://www.discountrcstore.com/CR192..._S_p/cr192.htm
joeymdz is offline
Old 02-06-2015, 08:56 AM
  #1302
Not in stock, as I just ordered a bunch of stuff from DRC (awesome service btw) and this wasn't in or looking to be in any time soon. Was hoping for alternative that others might have used successfully.
negatv1 is offline
Old 02-06-2015, 09:58 AM
  #1303
joeymdz's Avatar
RC Plus in Salem, OR has them (my local shop)
503.364.9188
joeymdz is offline
Old 02-06-2015, 03:31 PM
  #1304
You'll have to find a shop that has them in stock... theyre on worldwide backorder. I just asked about them a few days ago
Old 02-06-2015, 04:30 PM
  #1305
Yeah What Tony said! Also You might try turning your steering speed down on your radio. My experience has been that with todays servos being so fast, it does not allow the tires to grip in a consistent manner. It is possible you are putting so much "wheel" into the car entering the corner, the fronts are actually pushing slightly until you get back in the throttle. The throttle causes the chassis to rotate and thereby becomes loose. I may be up in the night on this, but it is very easy to overlook this minor adjustment. Slower steering also makes it easier to diagnose the problem. Plus if you don't like it, you can always just turn the speed back up.
Spikesef is offline
