Schumacher Cougar KF!!! >
Old 10-27-2014, 09:13 PM
  #1036
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
nice to see Wernimont steeling the TQ at EOS. i'd like to see that setup-- indoor carpet onroad-- err offroad should be coming to a bunch of tracks soon.
hanulec is offline
Old 10-27-2014, 10:13 PM
  #1037
DiscountRCStore's Avatar
+1 ..
DiscountRCStore is offline
Old 10-28-2014, 01:26 PM
  #1038
nm
Hamman9 is offline
Old 10-28-2014, 01:30 PM
  #1039
joeymdz's Avatar
Wernimont 's Setup:
http://www.petitrc.com/setup/schumac...nan2014102426/
joeymdz is offline
Old 10-28-2014, 03:06 PM
  #1040
Originally Posted by Hamman9 View Post
looking at buying a cougar kf with low grip conversion. I see that with motor in rear position shorty must be used but when motor is moved back forward can saddle pack be used like stock chassis without modification? thanks
The chassis that comes with the Low Grip conversion is cut to handle the motor mount in either position. In terms of modifications, you will just have to swap out or move the appropriate parts for the desired setup (belt, rear tensioner, posts, top deck pieces, etc.).
J.Pietsch is offline
Old 10-28-2014, 05:14 PM
  #1041
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Ya pretty impressive... Carson been killing it lately. To TQ EOS is a feat.... many US drivers have tried
Tony Newland is offline
Old 10-29-2014, 12:45 PM
  #1042
danmurphy's Avatar
Originally Posted by joeymdz View Post
Wernimont 's Setup:
I noticed he's removed 2 internal gears from the diff. Does anyone know what effect this has? Does it speed up the diff action by creating less resistance?
danmurphy is offline
Old 10-29-2014, 05:59 PM
  #1043
Less "shear" on the oil... so yes essentially a free'r diff
Old 10-30-2014, 01:03 AM
  #1044
Mustrum's Avatar
20 years ago most drivers removed balls in diffs, I don't remember why, but Cliff Lett did it, si we did...
Mustrum is offline
Old 11-15-2014, 07:04 PM
  #1045
Just moved to Socal and will be racing at OCRC, my SX3 runs great but going to be doing 2wd...How do guys think the KF will perform on that track straight out of the box. I know it's a high bite track but I've never had a mid mount 2wd before. Thanks
AJrollin is offline
Old 11-15-2014, 07:05 PM
  #1046
I'll be running stock 17.5.
AJrollin is offline
Old 11-16-2014, 08:53 AM
  #1047
ppascho's Avatar
dont know the grip of OCRC but if its high grip and you have the right tyres you will adore this car
ppascho is offline
Old 11-16-2014, 12:28 PM
  #1048
fmm
Default Shorty conversion set
Hi all
I am planning to buy the shorty lipo conversion for my KF, but I am not sure its benefits.
I am running in a medium bite carpet track, with some medium-big jumps.
I don't know if the shorty conversion is appropriate for this type of tracks or if is only for low bite tracks.
Can someone explain the pros and cons of the set?
Thank you very much in advance!
fmm is offline
Old 11-16-2014, 05:50 PM
  #1049
Carson Wernimont races at OCRC and he uses the SV2 last I checked. If you decide on the KF pick up the low grip conversion set... it will improve the car leaps and bounds
Originally Posted by fmm View Post
Hi all
The shorty kit has all but been replaced by the low grip set... with the low grip you can run the motor in the rearward position of std to your liking. That being said you could experiment with which layout works best for you in about 15mins to swap layouts
Old 11-17-2014, 06:15 AM
  #1050
fmm
Thank you very much for the reply! I appreciate it.
I know that, my point is that I am worried about investing I the low grip conversion and then don't use it on a carpet track. I haven't seen any of the team's setup using the low grip conversion on a carpet track, so this is why I was wondering its applicability.
I was more towards the shorty lipo conversion set. As I think that it is a good way to reduce the overall weigth of the car, without taking away too much weigth in the front.
But I am not sure if I am wrong about this hypothesis, so if you could elaborate a bit on both kits, I would appreciate it.
Thanks a lot!
fmm is offline
