Schumacher Cougar KF!!! >
Old 11-13-2013, 05:35 PM
  #61
spu83's Avatar
Also the belt on the KF is shorter and using smaller spur compare to K1.
spu83 is offline
Old 11-13-2013, 05:50 PM
  #62
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Exactly... being the internal ratio is adjustable like the SX and SV series via side gears, you can position the motor all over the place
Tony Newland is offline
Old 11-13-2013, 05:57 PM
  #63
Trader Rating: 18 (100%+)
We will have a couple of these hitting the tracks here in West MI as soon as possible!!
nhraman is offline
Old 11-13-2013, 06:02 PM
  #64
Old 11-13-2013, 06:05 PM
  #65
StupidHead's Avatar
Originally Posted by Tony Newland View Post
The almost, 20mm longer wheelbase (285mm) aids in weight bias to the rear. The original SV and SV2 both are very short (267mm), therefore putting much more bias on the front tires. If you picture the forward most part of either the motor or battery in both cars the KF is much further back than the SV2. With the majority of the weight further back the pivot point will be further back
That's not true, the KF has loads more weight on the front wheels than the SV2. The original SV was 267, but the SV2 was 8mm longer, so only 10mm shorter than the KF. If you look at the two side by side, even with that extra 10mm, it is still massively nose heavy compared to an SV2 (or any other MM car).
Hopefully you guys can come up with some good setups to counter the weight balance and I get my KF on the track.
Attached Thumbnails Schumacher Cougar KF!!!-sv2-kf.jpg   Schumacher Cougar KF!!!-sv2-kf2.jpg
StupidHead is offline
Old 11-13-2013, 06:09 PM
  #66
StupidHead's Avatar
This doesn't change the motor position at all, it is a vertical adjustment between the fixed position layshafts, the motor mount and thus motor position is not affected.
Old 11-13-2013, 06:15 PM
  #67
The SV2 is listed on Schumacher website as 267mm.... So the SV was 259mm?
The difference is the second pic you have is an SX3... the KF rear belt is shorter so that is not an accurate comparison to a SV2. The shorty mounted sideways is also misleading. With both cars built with same components the KF will be more rear biased.
The side gears do not by themselves, your absolutely correct, but if you change the internal ratio and change the spur/pinion to compensate and achieve the same FDR, the motor can be moved fore and aft
Old 11-13-2013, 07:15 PM
  #68
StupidHead's Avatar
The SV was 267, Schumacher have had the incorrect length on the site for the SV2 since day one.
Here is another picture to demonstrate using a K1 and SV2. I have moved the SV2 forward 10mm as I believe the KF does away with the battery tray. There is no way a motor and centre assembly will fit between the red lines. I was going to put the SX3 centre in there against the batteries to show the exact dimensions, but I don't want to re-mount everything. I can if you really want me to though.
Old 11-13-2013, 07:23 PM
  #69
Im not too worried, time will tell. Mine will be here early next week, Im hoping to get to the track one day for some practice before raceday
I wrenched on a buddies Centro B4 a couple weeks ago and made it push, so if we have that much grip this thing should be good to go
Old 11-13-2013, 07:56 PM
  #70
StupidHead's Avatar
Yeah, don't take me highlighting the different weight distributions out of context. I'm still very excited to get the car, even if it may not be much use to me. When I drove my converted SX3 on super high grip, it was the best car I had ever driven and that was with a slap together "setup", so the KF can only be better. On a track where you're running slicks, I'm sure it will be a good thing.
I'm still praying for a new 285mm SV2 though
Old 11-13-2013, 07:57 PM
  #71
trevcoll's Avatar
This might be my first Schumacher buggy in over 2 decades if it can be made to work on a medium traction indoor dirt track.
trevcoll is offline
Old 11-13-2013, 08:02 PM
  #72
I agree... in the right conditions MM is untouchable. back when I tried a SV it was only good 2 weekends a year... the 2 big races we had and the track grooved up good. The rest of the time it was absolutely undrivable. Longer was better on that car, and should be even better on this one. Im excited to try it
Old 11-13-2013, 08:15 PM
  #73
spu83's Avatar
Now the big question is when.
spu83 is offline
Old 11-13-2013, 08:38 PM
  #74
Very soon
Old 11-14-2013, 06:27 AM
  #75
Trader Rating: 8 (90%+)
You guys seen this?? KF domination at Silverstone.
http://www.racing-cars.com/scp/news/...partno=race748
juicy74 is offline
