Schumacher Cougar KF!!!
#556
Josh, with the side gears do you feel a rough part of the mesh when turning them with a slight increase in resistance or do they go really tight?
You could check each gear and look for any bruising on the teeth, and if found dress with a needle file.
My side gears were a bit notchy which gave a slight increase in resistance when turning by hand from new but they soon bedded in nicely. A small amount of grease quitens them down nicely as well.
#558
I was actually thinking that they would probably break in but good to know. Don't know on the caster blocks yet. thx
#559
I use B4 steering knuckles and stock caster blocks. Broke 3 knuckles in 3 weeks so switched to B4 and have not broken anything since.
#561
I run 5k in my gear diff. The car will drive much differently with the gear diff as opposed to the ball diff option. I think most guys are running the ball diff, but the gear diff works for me on high bite clay and is definitely better on carpet.
#562
Ok another issue. Step 30 installing front axles. The supplied m3x4 screw is to short. I tried a m3x6 and it works but the issue is if tightened the axle will lock. If left loose and then using thread lock then that is all your relying on to keep front axle together. One jump from me and tire will be flying off. Thought when installing bearings that they weren't seated all the way but they are. help!
#563
#564
#566
What was Carson running at Cactus Classis? SV2 or KF?
#568
I will post pics tomorrow when I get back in town. Bearings are seated correctly and are flush on both sides of the steering block. When sliding axle through it sits about 1mm away from coming contact with other side bearing. So when installing screw it will pinch the bearings. Anyways its probably something simple, but will post up pic tomorrow eve.
#569
