Schumacher Cougar KF!!! >
Old 12-26-2013, 05:40 AM
  #346
Originally Posted by spu83 View Post
I have SVR, SV2 and KF.
SVR will be the choice if the track is very loose.
The KF can soak up the bump better than SV2 (longer wheelbase and little heavier battery).
For now SV2 is my back up car and KF is my primilarly. There is a lot of tuning I have to try on KF and so far I am only playing with the shocks.
My choice is KF SV2 KR(SVR).
I will bring both MM this Sunday so you can try them out.
That would be great! So if I'm reading correctly, if you could only have 1 of them, you would chose the KF?
Hinecken is offline
Old 12-26-2013, 06:02 AM
  #347
Trader Rating: 9 (91%+)
Originally Posted by juicy74 View Post
Pulled the trigger yet, KC? I'm contemplating but not too sure how it'll work out at BTP. As it is, I'm having problems with the SV2 when the track is damp.
I was running it for the recent astro race at STK.
I'm just contemplating whether to redo the setup for dirt track.
On a damp track, even RM can also be a struggle.
leongkc is offline
Old 12-26-2013, 06:21 AM
  #348
Trader Rating: 8 (90%+)
NICE!!! What are your impressions? Doesn't look like you have an option to set up for dirt track or not. As far as I know, only employees of STK can use that track on a regular basis... unless of course you are one.
juicy74 is offline
Old 12-26-2013, 06:54 AM
  #349
spu83's Avatar
Yes it's a newer car and get better update features.
spu83 is offline
Old 12-26-2013, 07:09 AM
  #350
Not an employee, and that was my first time with both the car and track.
Easy to drive with the stock setup. Almost felt like a 4wd.
Why I'm contemplating this for even dirt is Tom's setup for low grip astro:
http://www.petitrc.com/setup/schumac...ill_RHR201312/
It does look interesting, as the weight bias is shifted much more to the rear. Worth experimenting so I've ordered a ball diff to try with it.
leongkc is offline
Old 12-26-2013, 05:31 PM
  #351
Dude, set it up for this New Year's Day race and let us know how the car handles on medium to loose dirt.
juicy74 is offline
Old 12-26-2013, 06:09 PM
  #352
Default tianhao motor
does anyone know if the tianhao ufo motor will fit in the kf?
cody.byrnes is offline
Old 12-26-2013, 06:36 PM
  #353
spu83's Avatar
http://www.redrc.net/2012/05/tianhao...shless-motors/
It's a 540 can it will fit but you may need to rotate the motor so the tabs are facing forward to clear the top deck. Changing motor will require take off the whole spur assemble.
spu83 is offline
Old 12-26-2013, 07:56 PM
  #354
vadersing's Avatar
Has anyone tried or seen the shorty conversion? I can't seem to find an image on google. Anyone?
vadersing is offline
Old 12-26-2013, 08:00 PM
  #355
vadersing's Avatar
Originally Posted by Tony Newland View Post
Order the conversion when its available
Has anyone seen the shorty conversion kit? Curious.....
Old 12-26-2013, 09:21 PM
  #356
Hey guys,
Just wanted to let you know that I have worked with 92zero Designs to get chassis protectors made for Schumachers. Today they posted they are ready!
Their website is being redesigned so you can see them on their Facebook page:
http://www.facebook.com/92zeroDesigns
Until the website is updated, feel free to email them with any questions you have. They have lots of design options, what's pictured are mine
[email protected]
J.Pietsch is offline
Old 12-27-2013, 02:00 AM
  #357
Default shorty version
Hallo all,
Pictures of the shorty version can be found here:
http://www.oople.com/forums/showthread.php?t=137978
Greetings
Hans
Hansie2 is offline
Old 12-27-2013, 05:34 AM
  #358
Has anyone tried this on a dry, dusty, clay track?
Hinecken is offline
Old 12-27-2013, 07:59 AM
  #359
Trader Rating: 38 (100%+)
I can't see the pics linked above for the shorty conversion. I purchased one with my kit but haven't installed it yet. It basically adds another belt tensioner on the right rear bulkhead and uses a longer belt. There are two plastic holders on either side that ride in the 4 little grooves in the chassis and the little tabs on the underside of the side protectors hold them in place, from my recollection it's 3 positions.
linkless is offline
Old 12-27-2013, 08:09 AM
  #360
spu83's Avatar
Yes it allows 3 different positions for the battery. If you take them out and put the center pieces back on and you can run the saddle pack without changing the rear belt.
spu83 is offline
