Schumacher Cougar KF!!! >
Old 12-20-2013, 12:00 PM
  #316
b_recliner's Avatar
Trader Rating: 22 (100%+)
No worries....order placed!!! Thank you.
b_recliner is offline
Old 12-20-2013, 12:10 PM
  #317
hairymuffin's Avatar
Trader Rating: 103 (100%+)
what other wings fit? i cant always get a schumacher wing...someone mentioned the rb6 jconcepts wings on the svr/kr thread but the step in the middle is too narrow..it sucks that they stopped making the max aero wing that came with the svr
hairymuffin is offline
Old 12-20-2013, 01:16 PM
  #318
Trader Rating: 15 (100%+)
I just forced a normal Jconcepts wing to fit, been working pretty good so far
fivepointnine is offline
Old 12-20-2013, 04:36 PM
  #319
Trader Rating: 8 (90%+)
Bmax2 wings are flat and should fit. I use them on my sv2.
juicy74 is offline
Old 12-20-2013, 05:17 PM
  #320
casey3v's Avatar
The centro wings also work well
casey3v is offline
Old 12-21-2013, 12:53 AM
  #321
But the talon wings look the best
juicy74 is offline
Old 12-21-2013, 07:31 AM
  #322
Schumacher KF for sale in the classifieds area.
To everybody that knows me, don't bust my chops over this!
speed90 is offline
Old 12-21-2013, 10:30 AM
  #323
So so tempted....
juicy74 is offline
Old 12-21-2013, 10:35 AM
  #324
Trader Rating: 18 (100%+)
Originally Posted by juicy74 View Post
So so tempted....
Speed90 and I got these cars at the same time, it's a shame that our track closed. This car truly only has about 10 minutes of run time on it. Buy with confidence.
nhraman is offline
Old 12-21-2013, 11:19 AM
  #325
FYI in a PINCH you can use AE steering knuckles. I broke one last night before my heat and swapped in Associated knuckles, axles and hexes. There is a lot of play since the spindle diameter is different, but I still managed to run a personal best in the 1st heat last night.
Old 12-21-2013, 09:09 PM
  #326
thanks...Also thanks guys for the heads u on the wings,I had already considered the yoke and centro wings since they are flat..plus the jconcepts wigs are $10 for 2
Old 12-21-2013, 09:45 PM
  #327
JsK
JsK's Avatar
I think the one that fit was the rb5 wing.
http://www.amainhobbies.com/product_...Wing-65-Wide-2
JsK is offline
Old 12-22-2013, 01:35 PM
  #328
Yes, the AE steer knuckles will work in a pinch, but it is a process and expensive to get them to work properly. I've used the AE knuckles and ball studs, Jconcepts axles, and Avid hexes and bearings to put together a solid assembly. You will need to drill out the hole in the knuckle with an 1/8" drill, pick up some 1/8" brass tubing from hobby lobby or LHS and make a sleeve so the pin has no slop. I've found it much easier to keep a extra set or two of the Schumacher knuckles in my pit box vs. going this route. I hope this helps anyone that finds themselves in a bind, here's a few pics of my completed assemblies.
Attached Thumbnails Schumacher Cougar KF!!!-steer-1.jpg   Schumacher Cougar KF!!!-steer-2.jpg
nhraman is offline
Old 12-22-2013, 03:34 PM
  #329
Tony Newland's Avatar
Trader Rating: 53 (100%+)
We ran the AE stuff sleeved before the schu hex stuff came out. Id just pick up some spare knuckles... the newest ones are updated and are stronger to boot. They should say V2 on the package
Tony Newland is offline
Old 12-22-2013, 04:56 PM
  #330
Lightbulb
Yeah I have extras that will be in Tuesday, hopefully I get the updated ones!
