Fan Mount
Old 10-30-2013, 11:13 AM
Default Fan Mount
I am looking for ideas on a way to mount a motor fan on a Associated SC10. Anyone got any ideas?
Cueball22 is offline
Old 10-30-2013, 11:29 AM
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
I assume you are talking about the motor
CCristo is offline
Old 10-30-2013, 11:30 AM
I mounted mine to the rear bumper bracket that runs over the motor. Just use zipties and make sure it is blowing down on the motor.
Rawwolf is offline
Old 10-30-2013, 11:53 AM
ThePanda's Avatar
Trader Rating: 68 (100%+)
You shouldn't really need a fan
ThePanda is offline
Old 10-30-2013, 12:38 PM
lbenton's Avatar
Trader Rating: 48 (100%+)
I imagine a good motor mounting plate acting as heat sink will do more work than a fan back there. The motor on a 2wd is generally wrapped up in enough vehicle that air flow will not be improved much by a fan.
lbenton is offline
Old 10-30-2013, 02:18 PM
CCristo
Just what I am looking for. I assumed I needed some type of mount. Pretty simple design you have. Do you notice a difference in motor temperatures?
Old 10-30-2013, 02:19 PM
Rawwolf
Do you have a picture of how you have yours mounted?
Old 10-30-2013, 03:24 PM
ThePanda's Avatar
ThePanda is offline
Old 10-30-2013, 05:03 PM
CCristo's Avatar
Originally Posted by Cueball22 View Post
CCristo
That's not my truck, it's Ryan Maifield's. Depending on what fan you run, you can see a pretty significant drop in temps. If you are looking for a fan, the WTF ones are supposed to be pretty good, although I've never used one.
CCristo is offline
Old 10-31-2013, 10:12 AM
This is where mine is mounted, but instead of screws I use zip-ties.
Rawwolf is offline
