Castle Rotor Issue  ANY HELP? >
Old 10-29-2013, 04:47 PM
  #16
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 66 (100%+)
Originally Posted by wittyname View Post
This is hilarious . I just sold one of these for about 10 more dollars then the rebuild kit . Do yourself a favor and just find ya a motor .
It is pretty hilarious to pay 90 bucks for a motor, when you can spec out a simliar spacer and order it from any place off of google for prices between 5-10 bucks if even that.
Go ahead and keep paying high prices instead of thinking outside the box.
Darkgenerals is offline
Old 10-29-2013, 05:05 PM
  #17
wittyname's Avatar
Your right . Good luck with the fix...
wittyname is offline
Old 10-30-2013, 05:06 AM
  #18
lemonader83's Avatar
Trader Rating: 16 (100%+)
looks like I'm pulling apart a motor tonight! i refuse to believe the bushing is gone as this motor worked like a champ prior to the break and I've had it for over a month and run this car in particular very often.
hmmm... $90-$110 for a new motor?
(or) $2-$3 for a spacer? +blood, sweat and more than likely tears...
let's be honest, I have time to try fixing it and could care less if i bleed.
i'll try it out and let you all know the results!
lemonader83 is offline
Old 10-30-2013, 05:15 AM
  #19
I won a 30% off castle card at race other day. If you end up needing something from them you can have the code off it. I don't use them
turtletrax is offline
Old 10-30-2013, 07:08 AM
  #20
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
What has happened is the rotor has debonded from the shaft(I have had this EXACT thing happen to me) , you might be able to fix it with Loctite sleeve retaining compound . But IMO you are better off getting a rebuild kit or buying a new motor ..
http://www.permatex.com/products-2/p...etainer-detail
BashemSmashem is offline
