Old 06-30-2005, 10:16 AM   #1
wlvrn's Avatar
Default mounting new engine?
i have a nitro sport that im converting to a rusty and im getting a new engine for it. will i need any motor mounts or will my existing ones work? heres the engine i will be getting: o.s. .12 cv-rx (s) w/ 10er rotary carb http://www2.towerhobbies.com/cgi-bin...2&I=LXXA43&P=K
wlvrn is offline   Reply With Quote
Old 06-30-2005, 11:20 AM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
Yes your engine mounts will work. If you've got the trx pro .15 in there now it will bolt right in. Although you may need to cut down the crank shaft threads to bolt the clutch up.
WheelNut is offline   Reply With Quote
Old 06-30-2005, 01:20 PM   #3
wlvrn's Avatar
cool. i cant wait to get this all put together. thanks
Old 06-30-2005, 06:38 PM   #4
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Tell us how it goes.
Sean
Team Duratrax is offline   Reply With Quote
Old 07-03-2005, 10:07 PM   #5
wlvrn's Avatar
i was messing around this weekend, b4 i took everything apart, and brok the plastic axle. god i had plastic i have it all apart now and am waiting for the local shop to open up so i can get an ht servo for it.
what would be a better axle to get? do they make a better one than plastic? what about metal suspension arms too?
Old 07-04-2005, 03:07 AM   #6
Go to www.fastlanemachine.com they have plenty of aluminium upgrades for the nitro Rustler.
Sean
Old 07-04-2005, 08:48 AM   #7
wlvrn's Avatar
thanks td
which screws, out of the upgrade from sport to rusty conversion kit, hold the engine mount to the frame plate? is there a link that shows which screws go where and how the new steering is put together?
Old 07-06-2005, 02:53 PM   #8
wlvrn's Avatar
what about the axle? does anyone make a metal one? i looked on tower hobbies and couldnt find the axle i need for my rusty. can someone help?
Old 07-07-2005, 03:12 AM   #9
www.fastlanemachine.com might have some outdrives.To download the owners manual for the Rustler go here. http://www.traxxas.com/products/nitr...x_nrustler.htm it will show you how the steering is put together.
Sean
Old 07-07-2005, 07:13 AM   #10
wlvrn's Avatar
thanks again td
i couldnt find axles there. maybe ill email them today and ask.
Old 07-09-2005, 06:58 PM   #11
wlvrn's Avatar
how do i take the clutch of my pro .15 and put it on my os .12? i cant seem to get if off
Old 07-10-2005, 03:35 AM   #12
What problems are you having with taking off the clutch? It should come straight off if you removed the e-clip that holds the whole clutch assembly together.
Sean
Old 07-10-2005, 12:19 PM   #13
wlvrn's Avatar
where is the clip located? i have the piston out, the pull starter off along with the plate it bolts to, and the pinion off.
Old 07-10-2005, 04:58 PM   #14
Hmm maybe your clutch is held on with something different.Anyway now that you have the clutch bell off the whole clutch assembly should slide off the engine shaft.
Sean
Old 07-10-2005, 06:42 PM   #15
wlvrn's Avatar
is the clip on the shaft that the clutch bell screws onto? it looks like there might be one there but there is no way i could get it off without breaking something
%%%% RC8 FT Engine Mount and 2 Engine Mounting Plates jf45 R/C Items: For Sale/Trade 0 05-12-2008 04:56 PM
Engine mounting screw catkchun Malaysian R/C Racers 28 10-19-2007 07:31 AM
rc10gt engine mounting Q NiTeHaWk4787 Electric Off-Road 7 08-10-2006 08:15 PM
engine mounting problem krnfx Nitro On-Road 2 07-14-2006 06:34 AM
RC10GT Engine mounting Ryan C. Electric Off-Road 10 12-18-2005 04:00 PM
