Old 07-10-2005, 06:56 PM   #16
wlvrn's Avatar
got it i desided to put it in the vise and tap it with a hammer. it came right off
wlvrn is offline   Reply With Quote
Old 07-10-2005, 07:38 PM   #17
wlvrn's Avatar
one problem after another...this is getting old fast...now the engine will not fit cos the pull start is to big for the engine mounts. what mounts will work? do i need to shave material to make it fit?
Old 07-11-2005, 12:55 AM   #18
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Are you saying that the engine mounts are that low that the pullstarter touch the chassis? I don't know of any different engine mounts but you could always buy a bump starter like this one http://www2.towerhobbies.com/cgi-bin...?&I=LXRS98&P=7
Sean
Team Duratrax is offline   Reply With Quote
Old 07-11-2005, 06:23 AM   #19
wlvrn's Avatar
they dont touch the chassy. the pull start hits the mount and wont allow it to sit on the mount, about 1/16" off the mount and about 1/8" to go till the holes, engine and mount holes, line up
what about getting one of these?
http://www2.towerhobbies.com/cgi-bin...2&I=LXHPR4&P=K
is there a smaller pull start for the o.s. engine?
Old 07-11-2005, 08:19 PM   #20
I think you would still have the problems you are facing now with that starting system because it requires that you attach the gearbox onto the backplate which is probably the same size as the pullstarter.
You could try grinding some meat down on the mounts
Sean
Old 07-12-2005, 08:22 AM   #21
wlvrn's Avatar
im getting my dremel back from a buddy tonight so i can do that
Old 07-17-2005, 08:07 AM   #22
wlvrn's Avatar
engine mounted it took some grinding down but i got it to work. i also had to take a noch out of the chassy cos of the pull starter but it works and its mounted. now i just need to get the steering done.
im going to get a tuned pipe, which one would be good to get?
Old 07-18-2005, 06:34 AM   #23
Good to see you you got it mounted.
As for tuned pipes i really don't know which one would be good for you.AE, Losi and CVEC make some nice ones for .12 engines http://www2.towerhobbies.com/cgi-bin...es&FVPROFIL=++ Losi pipes can be found on www.stormerhobbies.com
Just remember that a small-thin pipe will be more effective down low.
A short-stubby pipe will be more effective in the higher RPMs.
I may have the wrong way around though.
Sean
Old 07-19-2005, 07:34 AM   #24
wlvrn's Avatar
iv been looking at these,
http://www2.towerhobbies.com/cgi-bin...2&I=LXFWE4&P=K
http://www2.towerhobbies.com/cgi-bin...2&I=LXCWH0&P=K
http://www2.towerhobbies.com/cgi-bin...2&I=LXN380&P=K
%%%% RC8 FT Engine Mount and 2 Engine Mounting Plates jf45 R/C Items: For Sale/Trade 0 05-12-2008 04:56 PM
Engine mounting screw catkchun Malaysian R/C Racers 28 10-19-2007 07:31 AM
rc10gt engine mounting Q NiTeHaWk4787 Electric Off-Road 7 08-10-2006 08:15 PM
engine mounting problem krnfx Nitro On-Road 2 07-14-2006 06:34 AM
RC10GT Engine mounting Ryan C. Electric Off-Road 10 12-18-2005 04:00 PM
