Motor solder tab loose >
Old 10-13-2013, 03:52 PM
teeforb's Avatar
Trader Rating: 94 (100%+)
Default Motor solder tab loose
I have a rev tech 7.5t motor. One of the solder tabs are loose. Not sure how to fix it. Any suggestions?
teeforb is offline
Old 10-13-2013, 04:04 PM
dmayhew25's Avatar
Trader Rating: 14 (89%+)
Just use a drop of CA glue to hold it in place.
dmayhew25 is offline
Old 10-13-2013, 04:23 PM
teeforb's Avatar
Have you don't this? Will this be an issue with glue and heat?
teeforb is offline
Old 10-13-2013, 04:28 PM
Crash74's Avatar
Either CA or a dab of epoxy. Have done it before and never had an issue with heat.
Crash74 is offline
Old 10-13-2013, 04:31 PM
teeforb's Avatar
Sweet! Thanks
teeforb is offline
Old 10-13-2013, 04:50 PM
Trader Rating: 222 (100%+)
+1
I have also unsoldered the tab and placed epoxy right under the tab. Than resoldered.
Manatarms25 is offline
Old 10-13-2013, 05:10 PM
dmayhew25's Avatar
Originally Posted by Manatarms25 View Post
+1
Careful doing this if you race where they may tech motors this I would doubt would be considered legal. A little thin CA will hold the tab in place with no problems.
Old 10-13-2013, 05:16 PM
Ya happened to my d3.5, just a drop of glue and it's fixed
xTotalghost is offline
Old 10-13-2013, 05:39 PM
teeforb's Avatar
It seemed to work for me.
teeforb is offline
Old 11-07-2013, 07:45 AM
Jack302's Avatar
Trader Rating: 22 (100%+)
Questions??
This happened to me with my trinity motor also what is the best glue to fix this?
Jack302 is offline
Old 11-07-2013, 07:51 AM
Trader Rating: 57 (100%+)
I've done both of these also. Only noticed it with my Trinity motors I use my tire glue. Losi standard.
I doubt they'd even notice. After doing it, I can't even tell and I did it!
shagino is offline
Old 11-07-2013, 07:52 AM
1967Typhoon's Avatar
Trader Rating: 35 (100%+)
Just some CA (superglue) is fine. I also had this happen, and I also repaired with superglue. Has held up great, and I crash A LOT.
1967Typhoon is offline
Old 11-08-2013, 08:48 PM
Jack302's Avatar
Ok thanks i'm going to use my tire glue.
Jack302 is offline
