Old 10-06-2013, 09:28 PM   #1
Precision1's Avatar
Trader Rating: 40 (100%+)
Questions?? Motor drive shaft/bearing fit question
I have 3 brushless 1/8 motors by different mfgs. All the motor shafts have a pretty tight fit (when new) with the bearings, you cannot feel play in them and they don't really move if you try to push the shaft into the can.
I just got my first 1/10 size motor and it is quite easy to move the drive shaft/rotor assembly in the bearings. I removed the back cover and you can see the shaft sliding freely in the ID of bearing. It is brand new.
Is this OK or normal? Seems like something spinning that fast should have a tighter fit w/ the bearings.
Precision1 is offline   Reply With Quote
Old 10-06-2013, 09:37 PM   #2
KOULLIT's Avatar
Hi Precision1,
As you can see with this pitcure :
The motor case is the drawing at the right down of the picture.
So the axle needs to be "free" into the inner ring.
But you can't compare the tolerances then the radial play between the axle and the bearing, and the axial movement, these are 2 different things !
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
