Nutdriver sizes
Old 10-04-2013, 08:51 AM
Default Nutdriver sizes
Hello. I am looking to place an order for wiha nutdrivers, hex drivers, phillips and flathead drivers with the full size handle I was hoping you can guys can list the sizes for each in sae and metric that will cover 99% of what I will need to work on my cars. Any help is appreciated.
Thanks,
Steve
SteveV is offline
Old 10-04-2013, 08:54 AM
Mason's Avatar
Knowing what cars might help.
Mason is offline
Old 10-04-2013, 09:06 AM
5, 5.5, 7, 8mm nut drivers
1.5, 2, 2.5, 3mm hex drivers
3/16, 1/4, 11/32" nut drivers
.050, 1/16, 5/64, 3/32" hex drivers
That should get you very close to what you will need
JLinney is offline
Old 10-04-2013, 09:10 AM
lbenton's Avatar
Trader Rating: 48 (100%+)
Yup, gotta know the size of your nuts.
lbenton is offline
Old 10-04-2013, 09:14 AM
serpent cobra 811e, rc10b3, kyosho zx5, some hpi, t22b, mini t and i'm sure there are others.
SteveV is offline
Old 10-04-2013, 09:53 AM
asc6000's Avatar
Trader Rating: 15 (100%+)
I'll answer your next question which is the subject of the weekly "best tool" threads.
MIP and Hudy best hex tips, all others choose by handle preference.
asc6000 is offline
Old 10-04-2013, 01:58 PM
I'm also new to this but metric are as follows.
M2 button/flat 1.3mm driver
M2.5 button/flat 1.5mm driver
M3 button/flat 2mm driver
M4 button/flat 2.5mm driver
M5 button/flat 3mm driver
M2 cap 1.5mm driver
M2.5 cap 2mm driver
M3 cap 2.5mm driver
M4 cap 3mm driver
M5 cap 4mm driver
M2.5 set screw 1.5mm driver
M3 set screw 1.5mm driver
M4 set screw 2mm driver
M5 set screw 2.5mm driver
M6 set screw 3mm driver
M2 bolt 4mm nut driver
M2.5 bolt 5mm nut driver
M3 bolt 5.5mm nut driver
M4 bolt 7mm nut driver
M5 bolt 8mm nut driver
M6 bolt 10mm nut driver
rc2013 is offline
Old 10-04-2013, 03:39 PM
ThePanda's Avatar
Trader Rating: 67 (100%+)
I second mip! I wouldn't pay out the top dollar for Hudy though unless I have real need.
ThePanda is offline
Old 10-04-2013, 05:49 PM
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Even though Hudys top dollar the MIPs better. Have both. Kept the hudy nut drivers since MIP does not make em but for hex drivers MIP is the best.
aloksatoor is offline
Old 10-04-2013, 09:11 PM
Thanks for the information, this narrows it down.
SteveV is offline
Old 10-04-2013, 09:43 PM
asc6000's Avatar
flat, button, set, cap, all the same hex / tool per size
only a few really needed for either metric or american
Almost none are a full size handle other than MIP.
For nutdrivers and phillips with big handles just use "regular" tools.
The quality of non-hex tools is not as critical.
asc6000 is offline
