Old 06-24-2005, 03:40 AM   #1
Default Losi Gold Ti-Nitride Shock Shaft
Has anybody had trouble with the Losi Gold Ti-Nitride shock shaft pulling out of the rod end. I never had this happen until I got the new Threaded Shock with my Adam Drake 1 XXX-NT. I have had two pull loose in wrecks last race, I know local racing is harder on parts that At a big event where the drivers are better.
I have checked the threaded end and it is .015" smaller that the stock silver shock shafts. I think I am going to put the silver ones in the threaded shock bodies so I can finish a race.
Thanks, Rick Harris.
Losi Jet Pilot is offline   Reply With Quote
Old 06-24-2005, 06:38 AM   #2
Send a message via AIM to TeamRoy
I know alot of the gas guys glue the shock end onto the shaft, helps prevent it from pulling out.
TeamRoy is offline   Reply With Quote
Old 06-24-2005, 08:43 AM   #3
T. Thomas's Avatar
If the shock shaft has been pulled out of the shock end, you should replace with a new shaft and then glue it like Team Roy suggested. The reason for replacing it is because even the first time it gets pulled out, it can round the tips of the threads over and thus will always be easy to get pulled off, even with them being glued on.
T. Thomas is offline   Reply With Quote
Old 06-24-2005, 09:00 AM   #4
Sofast-NT's Avatar
I have never had that happen,I use the MIP shock shafts they lasts longer and are $ 2.00 cheaper.
Sofast-NT is offline   Reply With Quote
Old 06-24-2005, 01:05 PM   #5
Land whats up!! Thats a good tip, those stock shafts are high dollar, whear you racing this weekend, im going to overcash
D Mac is offline   Reply With Quote
Old 06-25-2005, 12:23 PM   #6
Sofast-NT's Avatar
I went to a friends house,but i'll be racing probably every weekend now.I usually race at the badlands,sumter,hartsville,lances,etc.
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 01:04 PM
shock shaft pliers? gonzo416 Electric On-Road 24 11-02-2006 05:27 PM
Shock shaft info andrewdoherty Electric On-Road 1 07-12-2006 06:47 AM
Hellfire Shock Shaft Wear mxermadman Electric Off-Road 2 04-04-2006 11:02 AM
New Shock Shaft Design? scoobydo Electric On-Road 34 06-16-2005 06:50 PM
