Team Associated/Centro C4.2 >
Like Tree1Likes
Old 09-19-2013, 08:02 AM
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 39 (100%+)
Default Team Associated/Centro C4.2
The Centro C4.2 kit has been released by Team Associated!
C4.2 Conversion Kit for the RC10B4.2 Buggy
The Centro C4.2 Mid Motor Conversion kit for the B4.2 is now available on RC10.com!
Designed specifically for very high-traction surfaces, the Centro C4.2 Mid Motor conversion for the B4.2 features a hard aluminum one-piece chassis, and an all-new molded gearbox and bulkhead assembly that positions the motor in front of the rear wheel centerline, creating a centralized weight balance.
Additional tuning possibilities are available with Centro's range of optional accessories, including front bulkhead brass weights, front brace, and carbon chassis side stiffeners.
C4.2 Conversion Contains
Hard CNC Aluminum Chassis
CNC Aluminum Rear Suspension mounts with inserts
Aluminum Battery X-Brace
Aluminum Lipo Battery holders
Molded Gearbox casing
Molded Rear Bulkhead
Idler gear, pivot and bearings
Carbon rear shock tower and body mount
Centre chassis tie-rod brace
Front Chassis Brass Posts
Aluminum battery posts
Wing mounts
Ball Studs
Various hardware
Pro-Line® Bulldog C4.2 body & wing
HQ Pictures and a brief writeup (courtesy of petitrc):
http://www.petitrc.com/setup/associated/setupc4.1/C4.2/
Here's some shots from the JConcepts Clash:
http://www.petitrc.com/setup/associa...ood2013090708/
Where to Buy
http://www.amainhobbies.com/product_...C42-Conversion
http://www.teamassociated.com/C4.2/?...gust+7%2C+2013
Instructions:
http://teamassociated.com/pdf/cars_a...manual_cat.pdf
Bodies
http://www.amainhobbies.com/product_...Clearance-Wing
BUILD TIPS
--Tip courtesy of RCBuddha--
  • The Avid Centering kit will fit to the Centro gearbox. You will need an additional 4-40 x 5/8 and 4-40 x 9/16 screws to replace the 440 x 3/8 screws that screw to the motor plate from the inside of the gearbox. I have the correct screws needed. Please PM me and I will get them to you for a small fee. Caution: The Battery X-Brace comes REALLY close to the gear cover. Some grinding of the gear cover may be needed. Here's some pics:
  • When installing the transmission onto the chassis, make sure to keep support turnbuckle not attached to the transmission. Put your battery in, screw down the battery brace and then attach the turnbuckle to the transmission. You don't want to flex chassis, and this will give you the correct length for the turnbuckle.
  • Transmission shims: You may need shims for the diff, below is the correct shims needed. My topshaft also needed to be shimmed. (Pictures coming later) First, shim the topshaft so that the gear sits flush with the idlers. Then add some to the other side so that the play is taken up. Pictures coming soon...
  • The rear shocks need to be shimmed away from the rear shocktower. I suggest 2-2.5mm of shimming on the uppermount. 3-3.5mm on the bottom shock mount. YMMV
    --Tip courtesy of JDM_DOHC_SiR
    OK guys finally got around to posting up some pic's of the areas of the rear arms with the area that needs to have 2mm taken off "as per" WC
    The stock arms come in at 37mm wide so it makes taking 2mm of them easy..you just need a cheap pair of calipers and measure 35mm
    Stock.. non-modified rear arms
    Stock non modified rear arm measurement
    Area's on the rear arms that need to have the 2mm of material removed
    Measurement of the rear arms after 2mm of material has been removed
    Side view of arms
    One more view
    Hope this helps some of you
    --Tip courtesy of Wild Cherry--
  • To replace the front chassis braces with blue:
    http://www.amainhobbies.com/product_...Standoff-Set-5
  • When using the B44 Wing Mount, use this brace:
    http://www.amainhobbies.com/product_...tandoff-Blue-4
  • Transmission build:
    add 3/16 x .010 axle shims (#7368) behind the crush tube on top shaft to remove excess play
  • B44 wing mod:
    switch out the two 4-40 button screws with 5-40
  • Rear arm mod:
    grind front inside of arm for diff outdrive clearance
    --Tip courtesy of BryanJ--
  • For sure the TC3/B44 diff shims are too small on ID to fit over the shoulder of the diff. It seems like 10x12 mm shims are a perfect fit. The gold Durango diff shim set (TDR310033) or Kyosho's set (KYO96647) for the ZX-5 should work. The Kyosho set has two color-coded thicknesses included.
    --information courtesy of JDM_DOHC_SiR--
    OK here is the weight difference on the following rear bulkheads and shock towers
    C4.2 Plastic = 7.8g
    GHEA = 9.8g
    JConcepts = 16.8g
    Now for the rear shock tower
    C4.2 Graphite = 8.2g
    JConcepts = 12.6g
    So your looking at a 17.5g weight gain from the OEM combo and a 15.5g over the GHEA/AE rear bulkhead/OEM tower combo...
    Alternative source for diff shims:
    http://www.rctech.net/forum/12677151-post747.html
Wanna convert your SC10 into a MM?
PM Slick1!
More pictures: http://www.rctech.net/forum/13003881-post3340.html
second customer getting his complete build, requested a polished and clear protecting bottom.
SETUPS
*via iterator*
http://tweakstation.com/2013/11/25/centro-c4-2/
*Via Petitrc and Arn0*
http://www.petitrc.com/setup/associa...entroC4.2.html
Smaller Editable Setup Sheet:
http://www.petitrc.com/setup/associa...tupSheetv2.pdf
*Via Team Associated*
http://www.teamassociated.com/pdf/ca...C4.2_Blank.pdf
Astro Turf:
http://www.teamassociated.com/pdf/ca...g_Stotfold.pdf
Indoor Clay:
http://www.teamassociated.com/pdf/ca...dahl_JBRL6.pdf
http://www.teamassociated.com/pdf/ca...ielke_OCRR.pdf
"Candyland" Outdoor track:
http://www.teamassociated.com/pdf/ca...lieri_ROAR.pdf
http://www.teamassociated.com/pdf/ca...field_ROAR.pdf
http://www.teamassociated.com/pdf/ca...d_Shootout.pdf
http://www.rctech.net/forum/attachme...up-resized.jpg
Batteries:
http://www.teamassociated.com/reedy/parts/details/314/
http://www.redrc.net/2013/09/exclusi...h-square-pack/
http://www.amainhobbies.com/product_...5C-74V-5800mAh
Optional Parts:
SNR Graphite:
http://www.snrgraphite.com/index.php...dex&cPath=4_42
Optional Battery Posts:
http://www.psm-shop.com/option-parts...cml-c4.2-4?c=5
Pre-Cut chassis protectors:
http://www.chassis-slaps.com/Chassis-Slaps-Store.html
http://www.liverc.com/news/new_produ...sis_protector/
http://www.amainhobbies.com/product_...otective-Sheet
MM Wing:
http://www.liverc.com/news/new_produ...or_rear_wing_/
Aluminum Rear Bulkhead:
http://www.teamassociated.com/parts/details/c0089/
Ghea Rear Pivot Blocks:
http://www.absolutehobbyz.com/produc...jtm3mkifglb8e3
Ghea Rear Aluminum Bulkhead:
http://www.absolutehobbyz.com/produc...ducts_id=15598
JConcepts Aluminum:
http://www.liverc.com/news/new_produ..._option_parts/
Carbon Fiber Front shocktower:
http://www.redrc.net/2013/12/jconcep...t-shock-tower/
Weighted Front Bulkhead:
C4.1/2 Brass 18g Front Bulkhead Brace:
C4.1/2 Delrin Front Bulkhead Brace:
C4.1/2 Brass 15g Weight:
C4.1/2 Brass 10g Weight:
C4.1/2 Brass 5g Weight:
C4.1/2 Brass 10g Underbellcrank Weight:
C4.2 Carbon Fiber LiPo Battery Holder:
C4.2 Carbon Laminate Chassis Side Braces and Posts:
Shared Parts with B4.2:
Yaiba:
http://www.tresrey-usa.com/yaiba-racing-ae-b4/
8Racing:
http://www.tresrey-usa.com/8-racing-...associated-b4/
Exotek:
http://www.exotekracing.com/b4-b44-s...ear-hubs-ver2/
STRC:
http://www.teamstrc.com/index.php?ro...tegory&path=60
Avid:
http://avidrc.com/product/5/accessories/
JConcepts:
http://www.jconcepts.net/store/index...=index&cPath=5
Factory One:
http://www.factoryone-rc.com/Products.html
MIP:
http://miponline.com/store/Associate...pUp-Parts.html
Suspension
***information courtesy of 07forester***
Associated Big Bore Rear Spring Rates: - The springs in italics are the "most" commonly used springs for the b4.2
• ASC91335 - 12mm Rear Spring (Black/1.90lbs)
• ASC91336 - 12mm Rear Spring (Green/2.00lbs)
• ASC91337 - 12mm Rear Spring (White/2.10lbs)
• ASC91338 - 12mm Rear Spring (Gray/2.20lbs)
• ASC91339 - 12mm Rear Spring (Blue/2.30lbs)
• ASC91340 - 12mm Rear Spring (Yellow/2.40lbs)
Associated Big Bore Front Spring Rates:
• ASC91325 - 12mm Front Spring (Brown/2.85lbs)
• ASC91326 - 12mm Front Spring (Black/3.00lbs)
• ASC91327 - 12mm Front Spring (Green/3.15lbs)
• ASC91328 - 12mm Front Spring (White/3.30lbs)
• ASC91329 - 12mm Front Spring (Gray/3.45lbs)
• ASC91330 - 12mm Front Spring (Blue/3.60lbs)
• ASC91331 - 12mm Front Spring (Yellow/3.75lbs)
• ASC91332 - 12mm Front Spring (Red/3.90lbs)
• ASC91333 - 12mm Front Spring (Orange/4.05lbs)
• ASC91334 - 12mm Front Spring (Purple/4.20lbs)
[/center]
RCBuddha is offline
Old 09-19-2013, 08:14 AM
t8rtot's Avatar
Trader Rating: 14 (94%+)
t8rtot is offline
Old 09-19-2013, 09:02 AM
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
Nice info for the thread
Wildcat1971 is offline
Old 09-19-2013, 10:00 AM
I saw a handful of them being run at OCRC last night.
cjcoffroad is offline
Old 09-19-2013, 10:03 AM
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I'd like to see what the setups look like on these.
t0p_sh0tta is offline
Old 09-19-2013, 11:35 AM
Trader Rating: 44 (98%+)
want that carbon shock tower
cobra408 is offline
Old 09-19-2013, 12:28 PM
Just got mine in the mail,, YEAHH,,, I've been running the C4.1 in carpet and it is a BEAST. C4.2 should be even better, and now that the Ryans are running them, should have great setups.
indybobb is offline
Old 09-19-2013, 12:32 PM
I recall AE saying they had no plans to put c4.2 setups on their website. If they win the worlds that "might" change, but I would expect them to appear on petitrc
Old 09-19-2013, 12:38 PM
I cant wat to get one i like the alum chassis it should keep the C O G nice and low.
blingy is offline
Old 09-19-2013, 04:45 PM
RCBuddha's Avatar
I will post setups to my original post as they come available. I'm a little surprised they haven't posted any of the setups they've been running so far.
RCBuddha is offline
Old 09-19-2013, 09:30 PM
CraigMBA's Avatar
Trader Rating: 22 (100%+)
First!
CraigMBA is offline
Old 09-19-2013, 09:42 PM
Guest
Originally Posted by CraigMBA View Post
First!
Quit showing off an put together. Hahaha
Heck I am on the fence, buy a losi 22 2.0 or the b4.2/centro conversion.
I wonder how the centro would handle a loamy outside track???
kyoshoracer77 is offline
Old 09-19-2013, 09:43 PM
gee-dub's Avatar
Anyone know of any SoCal retail shops, preferably in the IE, that have these in stock?
gee-dub is offline
Old 09-19-2013, 09:48 PM
Guest
I think u got to order it from associated.
Old 09-19-2013, 10:53 PM
CraigMBA's Avatar
First new build issue:
1. Centro specs two 4/40 x3/8" socket head screws in box three. They sent caps and won't fit. Luckily I have hardware.
2. There is 0.020 inches side to side play in the differential after the case is closed up.
3. The lack of hardware continues in box 12.
Other than the side play in the case, the transmission is quiet and fairly free.
Too tired to carry on, see you cats tomorrow.
CraigMBA is offline
