Schumacher Cougar KR 1/10th Competition 2WD >
Like Tree3Likes
Old 05-24-2014, 04:53 PM
  #766
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Mkae sure the 2 screws are always tight... you can run a longer screw than what the kit suggests. I only broke them on heavy impacts. Somethings got to break, better that than the chassis on other cars
Tony Newland is offline
Old 05-26-2014, 06:26 AM
  #767
Default Rear axles
I noticed that when using Avid wheels there is only a few threads of the axle sticking out. What's everybody doing to allow them to run Avid wheels. I hope they aren't chasing rear wheels all over the track.
Roken is offline
Old 05-26-2014, 06:28 AM
  #768
Default Medium or hard arms
One thing I don't see on set ups is choice of arms, med or hard. What has been working best?
Roken is offline
Old 05-26-2014, 07:39 AM
  #769
As long as you use the serrated nuts... no problems
Old 05-26-2014, 07:50 AM
  #770
Thumbs up
Thanks Tony! I see you been helping a lot of racers here. And a lot of LocTite.
Roken is offline
Old 05-26-2014, 07:53 AM
  #771
Ive never had a problem... been using avid wheels since the release of the SVR... couple years ago. I see more 22s lose wheels than anything haha
Old 05-27-2014, 03:38 PM
  #772
Trader Rating: 32 (100%+)
what pinion should be used with a 83 tooth spur with a 17.5 ?
thefnshow is offline
Old 05-27-2014, 04:28 PM
  #773
What tuning parts do you recommend out of the gate for the KR.
rippen is offline
Old 05-27-2014, 05:03 PM
  #774
The kit 83 t spur I believe is for mod. You need something like a 72 t for stock 17.5. I haven't calculated the pinion for 17.5 and 72t yet. Most set ups I found are only for mod.
Roken is offline
Old 05-27-2014, 05:26 PM
  #775
Trader Rating: 24 (100%+)
33/71 is where you need to start, then go up or down depending on where the timing sweet spot is.
With the stock 83 tooth spur, you can't get anywhere close to where you need to be for 17.5
Rhett McNair is offline
Old 05-27-2014, 05:28 PM
  #776
I never change the front arms, always run the hard ones, there much more predictable.
For the Rear,
Medium for low grip
Hard for medium to high grip
Old 05-27-2014, 07:20 PM
  #777
BAD007SUZUKI's Avatar
Trader Rating: 97 (100%+)
Anyone else run the Rcshox garo slipper disks? I love mine! Both KR and Aero.
BAD007SUZUKI is offline
Old 05-27-2014, 11:02 PM
  #778
Trader Rating: 9 (91%+)
For me?
Ball Diff.
leongkc is offline
Old 05-28-2014, 11:51 PM
  #779
RedBMaster's Avatar
Personally, I'd say extended chassis, emulsion shock caps, SVR wing mounts, and ball diff. A lot of other guys like the 5 deg front block with the lower front shock tower. I haven't tried that combo yet, but kit blocks and tower work great!
RedBMaster is offline
Old 05-29-2014, 03:50 PM
  #780
If you decide to keep the gear diff I would recommend going with a heavier oil (depending on surface traction that is) I run on a medium traction surface and found the 2K oil to be to light. Recently switched to 10K and notice a big difference.
Bleeder shock caps are a must for me.
I also recommend the KF wing mounts. It raises the wing a bit and provides more protection to the rear shock tower/upper transmission housing.
I am going to try the +5 degree front yokes this coming weekend.
So far I have only had two parts break on my KR. First was the upper transmission housing. This was really wierd because I didn't have any bad crashes and it broke while running my second battery. I replaced them and everything has been fine since (I believe it may have been a bad batch from the factory).
The second part I had break was the front bulkhead where the front shock tower attaches. I noticed it broke after a few practice laps (with no crashes) but I did have a couple good tumbles prior to that. Again I replaced the part and haven't had any other issues and I have taken a couple big tumbles as I am pushing a little harder now.
Over all, it's a great buggy. Can't wait for them to release thier SC Truck.
Riverbluff is offline
