Sensored Motor Question
Just received a new to me buggy (xxx4 G) and a Viper 6.5t motor for it. The esc I installed is a MMP. I am having a hard time currently with the sensor wire that I have as it is too short. I hooked up everything else for setting steering, esc etc and accidentally hit the throttle on the tx. To my surprise the motor ran normal (without the sensor wire), I do have the esc set to smart sence for the sensored motor. I took it out just to see what kind of speed the buggy had with the 6.5t and I was surprised as to how slow it was. My question is since the wires for the sensored motor is not plugged in am I losing speed? My SCTE has a 3800kv Castle in it and is definitely faster than this much smaller and lighter buggy with the 6.5t (which is about 6100kv). I know gearing could be everything just do not see it getting much better. So hopefully it is due to the wires being unplugged. If you lasted all the way through this novel I thank you for your time!!
As for the top speed you get, it could be gearing, could be limits set on the ESC, could be the EPA on the radio. Just take each thing one at a time and rule it out.
The mmp automatically switches to sensorless mode if the sensor wire is unplugged. Most escs will run fine without the sensor wire installed. As stated above, it will just be a little rougher at the bottom end. You will also loose any can timing adjustment.
Did you program your endpoints? Could be a reason why its slow. A 6.5t should still be fast no matter where the timing is at, unless the gearing is extremely low or epa isn't right.
I have the epa set to 125% and it has a 18t pinion. Going to take it up a few teeth right now. The motor has 15-45* for timing and right now I have it set the way it came, 30*.
Set max EPA, reprogram to the radio and see what it does. also might want to check castle link to make sure all settings are right.
Well smart sense is supposed to start it on sensor and then transfer at higher speed. so maybe it only goes a certain amount higher than the sensored speed. and because it didn't have sensor it just limited itself to that amount of RPM.
