losi 8ight t e setup
trying to set up up my losi 8ight t e and honestly I'm not the best but, with practice ill pick it up. figured i would look up some comparable set ups to use as a starting point and take it from there. i seem to only be able to find setups for nitro losi 8t t. I'm not sure but id imagine there going to be different for electric? theres gotta be a descent weight/weight distribution difference. I'm running the losi conversion with a tekin t8 setup using a 4s lipo. any advice is good advice. please, fill me in
Welcome to e-truggy! I have a losi 8-t 2.0 with the tekno conversion and I think I have a decent setup on it, at least it will give you a baseline:
Diffs: 7/7/3 (Sometimes go to 7/5/3 depending on the track)
Springs: Black front/Xray Violet Rears (little longer than the stock springs and just a touch heavier)
Shocks: Front-54/40w, Rear-55/30w (I think last time I went to 35w but may not have updated my sheet)
Shock location: Front - #2 inside, #2 inside
Ride Height: 25mm front, 29mm rear
Sway bars - Stock
Camber: 2 degrees front, -2 degrees rear
Motor/Esc/Battery: Tekin 2250/Hobbywing 150/Turnigy 4s
If you want a full setup sheet check out Todd Hodges general setup as that well get you going with a good baseline setup.
Sway bars - Stock
Sway bars - Stock
Sway bars - Stock
normally i just bash and thats a run what you brung thing. setups don't seem to change the outcomes that much. i stopped at a local track to try it out for the first time. for me and the car. what a slap of reality.lol it was totally all wrong. running badlands don't work. it wouldn't turn what so ever unless i totally came of throttle and even then it had terrible understeer. so, thats what I'm doing now trying to set it up better. put on a set of aka impacts soft. I'm imagining they'll do better then badlands on the track. thanks
Very similiar setups for the most part. I had the silvers (too soft) and the purples (too bouncy) and it was hard to get the correct ride height in the rear without having the collars cranked down almost to the end.
Badlands are great bashing tires but as you found out a poor race tire. Impacts are good but check what your local guys run, usually they can steer you in the right direction. Soft are a good compound as a balance between grip and longevity. We tend to run SS and S gridirons and I have a set of Calibers to try as well.
Good luck!
Good luck!
Good luck!
Good luck!
Glad to hear things went better. The part number is Xray 358287.
For the plastic block, never had a problem leaving it in. One thing I have done though is continue to use the metal spur. Little more noisy but much more durable. If weight is a concern go with the light weight metal spur.
