Thinking about a Tekin
#16
yes the pro4 hd is overkill for my track especially, I've seen some guys at my track running the hd and its ridiculous! If not tamed down unless you have very good throttle control, if I bashed more then raced I'd def. pick up the hd
#18
The 4600kv pro 4 is where its at if you insist on Tekin. I ran the 4000 kv and it was too slow at my track. Couldnt keep the nose up in the air either . Truck (scte) weighed 6.11oz. Same truck with 4600 and I couldnt be happier. The guys running the HD at my track have to run some large MAh packs to make 10 minutes. If you go the Pro 4 route , the right esc is a integral part of the equation to get the performance out of the motor you will be looking for.
#19
For your needs, the Pro 4 4600 may be the best bet. Plus, if you ever decide to get into any racing that is ROAR related, you will already be covered.
Pair it with an RX8 Gen 2, run the current limiter at 75-85 range, NO timing, and gear it 14/40. This will be a good all-around starting point.
