TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 12-13-2017, 09:35 PM
  #12781
ryan432greening's Avatar
You're a killer out there, Dave! Always fun running stock buggy against you. Only having a stock buggy now (for MNRC classes) I probably won't see you much, but when I do I'll be looking forward to it! I'll keep my eye out for the cars/parts. Hoping I won't need too much to get me through a couple years of barely racing it. The full body going on it for oval racing in the cold months should help save it a bit.
Originally Posted by Troubles Dad View Post
Hey Ryan, so can't beat them so join them? Just kidding as I won 17.5 buggy 2 years ago and Trevor got it last year, all with rear motor, my rear motor had 30 wt oil front and rear, no shim under the transmission, and 1 ounce of weight next to transmission, and 2 ounces around servo and on front of shorty lipo, I have parts for the 1.0 car along with 3 cars going up for sale, so if your interested hit me up, long live MNRC
ryan432greening is offline
Old 02-15-2018, 04:27 PM
  #12782
Trader Rating: 18 (100%+)
Default 22 2.0
Can the 22 2.0 MM still be a decent car for indoor hard packed racing what needs to be done to it as far as aftermarket stuff I picked one up to run off and on.
Tas4 is offline
Old 02-15-2018, 05:29 PM
  #12783
Lopaka208's Avatar
Absolutely it can. I recommend the 2 18g saddle weights to add to it. The car is great indoor.
Lopaka208 is offline
Old 02-15-2018, 07:19 PM
  #12784
Suspended
I would get the 3 gear transmission that TLR released. TLR332056 The 3 gear will make the car drive much better. It costs $35 and is still available on eBay. The 3 gear transmission will make the car better than adding weight.
urnotevenwrg2 is offline
Old 02-15-2018, 08:21 PM
  #12785
ttr_racer's Avatar
Trader Rating: 30 (100%+)
If anyone is interested I have a brand new in the package tlr body and decal sheet the cab forward version I also have an upgrade RC graphics kit with matching chassis protector for the original stock body. If anyone is interested just send me a PM with where you'd like me to send pictures and I will do so
ttr_racer is offline
Old 02-28-2018, 02:41 PM
  #12786
Rlmxracer is offline
Old 03-22-2018, 12:07 PM
  #12787
Can anybody tell me if the 22 3.0 12mm front axles will fit onto a 22 2.0 buggy?
Jconcepts made a conversion kit before the 3.0 came out but if the stock 3.0's fit that would be preferable as they're much cheaper.
Thanks,
Randy
Gliderflyer is offline
Old 03-22-2018, 01:42 PM
  #12788
Yes sir, 3.0 and 4.0 front axles fit
Old 03-22-2018, 08:49 PM
  #12789
Great, thanks for the info.
Old 04-15-2018, 06:05 AM
  #12790
gdiddy's Avatar
Is there a sway bar kit for the TLR 22 2.0 buggy?
gdiddy is offline
Old 04-15-2018, 11:25 AM
  #12791
Casper's Avatar
Trader Rating: 34 (100%+)
Not that I am aware of
Casper is offline
Old 04-15-2018, 01:49 PM
  #12792
Suspended
If you really want sway bars it can be done.
4.0 front arms and the other stuff needed from the front will work.
The 4.0 rear arms will fit with spacers and work, but you would have to run the 4.0 arms need to be switched left to right for them to line up correctly on a 2.0 From there you would have to make your own bars to work with the 4.0 arms. You could use the hardware from the 4.0 rear sway bar kit to figure something out, or use whatever you can find that will work.
I would keep the plastic type the same whatever you do. I would not get Stiffezel arms if you are only switching the front arms. Luckily 4.0 arms are available in the same plastic as the stock 2.0 arms. The stiffezel arms will probably make your car easier to drive on a surface that needs sway bars.
Old 04-22-2018, 06:34 AM
  #12793
gdiddy's Avatar
Can the TLR 3.0 buggy laydown transmission fit the 2.0 buggy?
gdiddy is offline
Old 04-22-2018, 05:02 PM
  #12794
NorthCentral RC's Avatar
Has anyone converted their 2.0 to a late model or modified oval car? If so, what parts did you use? I have trying to find the parts to do it, and no one makes anything for any losi buggy from what I can see.
NorthCentral RC is offline
Old 10-15-2018, 11:20 PM
  #12795
Sub
Can someone recommend an awesome esc/motor setup for my newly built losi 22 3.0 Spec Racer kit? My budget is around $200.. I want to do some club races and get the best for future needs (whatever that may be.. 1/10th scale racing, Losi SCT, crawling, 1/8?!). I definitely want brushless/sensored. I have a new 2s venom 4500mah 100c shorty pack to use with it, but I could see trying 3s later for bashing. I'm leaning towards the mamba x because it seems really flexible but I have no clue which motor to get (or motor/mamba kit). The tekin stuff looks cool too. I'm not an orion fan really..not sure why, they're website sucks .lol. Castle sidewinder/ 4600KV seems popular, but I can do more with my budget right??! Is it worth spending more?! I want this new buggy to seriously rip.
I really have no idea which KV motor to choose.. I'm using the stock 69 spur for now, and have a few pinions to choose from. Thanks for any info. I wanna buy something today if possible.
Sub is offline
