TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-10-2013, 07:21 AM
  #1216
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by RandyJones
How soon before Illinois has the cars in stock?
All orders placed should have shipped from the CA DC. IL has some cars headed their way that should be there sometime this week, or early next.
Frank Root is offline
Old 09-10-2013, 07:26 AM
  #1217
pink_sleeve's Avatar
Trader Rating: 221 (100%+)
Originally Posted by Frank Root
We are looking into this issue, and will hopefully have it fixed within a day or 2. The sheets work fine on a regular PC, it appears to be an iOS compatibility issue.
I could sleep, but then the 22 2.0 wouldn't have shipped yet
Well that sucks I only have an IPhone and an iPad I was trying to see the difference in the shock package/spring setup between the 3
pink_sleeve is offline
Old 09-10-2013, 07:30 AM
  #1218
RPS52's Avatar
One other thing, now that I'm further into the shock assembly steps. The kit setup sheet indicates 30wt oil, but the kit came with 27.5. What is everyone using for oil? 27.5w?
RPS52 is offline
  #1219
zi032's Avatar
The setup sheets come up blank on my Android Samsung Galaxy Note 2 as well so i dont think the problem is limited to ios. Glad to hear you guys are working on it though. Just trying to help.
zi032 is offline
Old 09-10-2013, 07:31 AM
  #1220
You could download adode reader, that should help.
rphbx is offline
Old 09-10-2013, 07:37 AM
  #1221
Same thing with Android - You could download adode reader, that should help.
rphbx is offline
Old 09-10-2013, 08:01 AM
  #1222
smac's Avatar
Finished mine up and ran it last night in mid motor config on a med bite track.
Couple of things I found that are important to know.
Mid motor with a shorty pack is an extremely tight fit...too tight. Had to shave the front battery holder down and install 3/8 " round standoffs on both sides of shorty to keep it from sliding side to side.
Check your aftermarket front wheels for clearance...DE Racing front wheels for the 22 will not work without the webbing hitting on the steering blocks when flexing throught the corners or la.ding some jumps.
New shock changes are amazing...very smooth.
New steering ackerman makes the steering a lot smoother...less aggressive and does not seem to free up the rear end as much when you throw it into a corner.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-imag0337.jpg   TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-imag0334.jpg   TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-imag0336.jpg
smac is offline
Old 09-10-2013, 08:04 AM
  #1223
Frank commented on this a few pages back.
The kit was intended to include 30wt, but a late found issue meant it came with 27.5wt for the first production shipment. I'd suggest using TLR or Losi shock oil for your kit builds, since the TLR and Losi oils are tested and certified accurate, while the kit oils are not. The reason for this is that the TLR and Losi oils are made in the US, while the cars are not.
Dave H is offline
Old 09-10-2013, 08:14 AM
  #1224
TLRacing
Frank Root's Avatar
Well, Dustin and Dakotah's setups are from an EXTREMELY high traction sugar water track, so unless you are running on one of those, I wouldn't recommend using their shock setups.
My shock setup is to use White LF rear springs, kit pistons, 30fr, 27rr, and 2mm front limiting with the rear unscrewed 1 turn.
Old 09-10-2013, 08:21 AM
  #1225
JBrad's Avatar
Frank I'm somewhat new to this buggy and set ups in general. I'm running your stock set up which I like but im curious to know what minor changes to it you would recommend for various track conditions? I noticed a few pages back you did some minor changes for the pegasus round what prompted the change? I mostly run at IERC but plan to do most if not all of the winter top notch series in the winter.
JBrad is offline
Old 09-10-2013, 08:22 AM
  #1226
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
did you add weight to your chassis with the shorty pack?
ryanpatrickgore is offline
Old 09-10-2013, 08:28 AM
  #1227
RPS52's Avatar
Thanks! I've tried to keep up with this thread, but missed that one.
RPS52 is offline
Old 09-10-2013, 08:29 AM
  #1228
smac's Avatar
I did add the TLR 50g weight to the rear bulkhead.
smac is offline
Old 09-10-2013, 08:55 AM
  #1229
I just wanted to pop in and mention something about the 22 rtr gear diff. I had installed a rtr gear diff a while back and didn't run the car for a while. I rebuilt it mid motor for a new track but noticed the gear diff was leaking. I wasn't able to find a package of just the gasket and o-rings.. the gasket comes with a diff case iirc and the o-rings come with outdrives.. both of which i didn't think i needed. I ended up digging through forum threads to find out what size o-rings they were and ordered up a set. I ended up getting orange p5 o-rings and they fit perfectly and i haven't had an issue with leaking since... thats about 3 race days.
I guess i'm suggesting that a rebuild kit be offered for the gear diff for those of us who like to avoid the maintenance of ball diffs and don't have time or patience to dig through that many posts.
On a side note when i ordered the p5 o-rings i also ordered a new rtr gear diff. It was leaking in the package and has been leaking in my parts box since then =P I wouldn't even consider running it without first putting in the other o-rings. I recommend maybe updating this if a 2.0 rtr ever comes out..
neospud is offline
Old 09-10-2013, 08:58 AM
  #1230
Easy enough to do, it's certainly an active thread. Mr. Root alone has posted some 117 times, many of them multi part answers. Awesome support. Hope his lack of sleep doesn't hurt the quality!
Dave H is offline
