TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 10-28-2015, 09:37 AM
  #12151
oh thank you so much for the clarification there Frank!! makes total sense! Losi thought ahead!
iDChuck is offline
Old 10-28-2015, 07:12 PM
  #12152
I have a new 22 2.0 that I didn't build. It has the gear different with I believe 5k oil in it. When I give it throttle it pulls to the right. I run mostly on carpet. Do I need to toss the ball different in? What would be making it pull to the right. All bearings are good no drag that I have found.
I also just noticed the slipper is slipping more than it should so I'm going to work on that.
LosiMadMan is offline
Old 10-28-2015, 09:24 PM
  #12153
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Have you measured all shock lengths? That would be the next thing to check.
Frank Root is offline
Old 10-28-2015, 10:35 PM
  #12154
I noticed the price cut on 22 2.0 and some stores dont sell them anymore. Is this the classic sign of a successor in the making?
iDChuck is offline
Old 10-28-2015, 11:22 PM
  #12155
Thanks Frank I'll check that. Is the gear diff better to run on carpet or the ball diff? Seems like if the rear tires are breaking traction under hard acceleration that one tire is unloading more than the other causing it to pull one way or the other?
I haven't raced 2wd in a long time. I have run 1/8 and 4wd sct for the most part.
Old 10-28-2015, 11:56 PM
  #12156
TLRacing
Frank Root's Avatar
The guys usually run a gear diff on astro or carpet.
Old 10-29-2015, 12:06 PM
  #12157
Gravity Dodger's Avatar
Thanks Frank, my buggy had the same symptoms and sure enough one shock was longer than the other three.
Gravity Dodger is offline
Old 10-29-2015, 03:54 PM
  #12158
[QUOTE=LosiMadMan;14242602]I have a new 22 2.0 that I didn't build. It has the gear different with I believe 5k oil in it. When I give it throttle it pulls to the right. I run mostly on carpet. Do I need to toss the ball different in? What would be making it pull to the right. All bearings are good no drag that I have found.
Check Rear Hub For Spacer between bearings, My kids buggy was doing the same thing and it was missing that spacer in one hub. Took a while to find because when you remove rear wheel it spins free.
Sidewayz1 is offline
Old 10-29-2015, 07:21 PM
  #12159
Would like to try 3x1.4 pistons. I know a lot of guys are drilling there own, just curious if the AE, kyosho, or any other brand will fit the losi shock shaft??
killshot01 is offline
Old 10-29-2015, 08:38 PM
  #12160
Can't speak to other brands and their fit, but Losi does make this part themselves: http://www.amainhobbies.com/rc-cars-...233018/p445402
Christophoclese is offline
Old 10-29-2015, 08:47 PM
  #12161
mtn bkr's Avatar
Trader Rating: 18 (100%+)
The AE pistons will fit the Losi shock shaft. I had a spare B5 shock shaft laying around, so I test fit a Losi piston on it and it fits just like the AE piston does.
mtn bkr is offline
Old 10-29-2015, 08:58 PM
  #12162
Thanks guys, I'll give it a shot
Old 10-30-2015, 08:49 AM
  #12163
Trader Rating: 29 (100%+)
Running my 22 2.0 tonight on a semi-tight indoor clay track.
Using a Trinity D3.5 17.5 in the "mod" buggy class.
What is a good general starting point for pinion size? I'm using the stock spur.
xjwolfpacker is offline
Old 10-30-2015, 09:07 AM
  #12164
I would start at 32 or 33 and check temps every minute or so until you are sure you aren't going to overheat.
RyanH is offline
Old 10-30-2015, 09:24 AM
  #12165
TLRacing
Frank Root's Avatar
TLR sells them, already drilled for 3 x 1.4mm....
http://www.tlracing.com/Products/Def...odID=TLR233018
