TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 05-13-2015, 03:57 PM
  #11401
Mudcat981's Avatar
Originally Posted by Medicinal Coma View Post
Yes they are on the correct sides, and I am using the short chassis. No binding at all. Anti squat can be used as a tuning aide, as I am sure you know. 1 deg happens to work well for me and the track I run on with the buggy. I just thought maybe I missed something that was stated that the 2 - 2.5 anti squat was a must to use with the brass hinge pin block.
Sorry was answering the one who was having a binding issue. Yes the degree anti-squat is a tuning aide and is a personal preference, was just stating the standard setup, not what is mandated. of course nothing is mandated.
Mudcat981 is offline
Old 05-13-2015, 09:50 PM
  #11402
jag5508's Avatar
Trader Rating: 15 (100%+)
Thanks I pretty much got that all fixed new problem . My lipo don't fit lol . Anyone have a problem with the Trakpower shorty lipo ?
jag5508 is offline
Old 05-14-2015, 02:52 AM
  #11403
With the losi bellcranks, is there a 2mm trail option available?
2hundy is offline
Old 05-14-2015, 05:37 AM
  #11404
Andrew Gray's Avatar
No, there is no option for 2mm trailing spindles. They only spindle designed to be used with the bell cranks are the 4mm ones that are included. Using the older 2 or 4mm spindles will alter the ackerman and lot let you achieve full steering throw.
Andrew Gray is offline
Old 05-14-2015, 08:50 AM
  #11405
Thanks for the reply.
Is converting the emulsion shocks to bladders simply a case of fitting the bladders or do I need different shock caps too?
2hundy is offline
Old 05-14-2015, 10:11 AM
  #11406
The buggy wasn't originally designed to use a shorty in mid motor. I ended up designing a mid motor shorty mounting system that fits perfectly with no modification to the stock parts.
See the post a few pages back:
http://www.rctech.net/forum/electric...l#post13946013
RyanH is offline
Old 05-14-2015, 11:51 PM
  #11407
Default Steering Rack
Is there a certain way the steering bell crank has to be setup?
I've gone through three sets of servo gears and can't figure out what is causing it to fail.
I max out the steering epa just until it binds, then back off a couple of clicks. My epa ends up being around 90/150. The horn is biased to the right a tooth (when looking at it) and the servo horn is almost fully extended on right turn, but never reaches the point where it can get locked.
For some reason the gear will just fail and never has it happened in a crash or hard landing. It just fails... normally right around half steering.
I'm stumped. Anyone got any ideas as to what may be the issue here?
I'm using a Spektrum S6070 low profile servo and aluminum horn. Pretty much stock front end with stock spindles.
rdline is offline
Old 05-15-2015, 04:29 AM
  #11408
I have the Savox SC-1251 in my buggy, which should be about the same as the spektrum low profile. My servo is 2-3 years old with the original gears and I race every week if I can. You could always switch back to the plastic horn to take the edge off whatever shock the servo is seeing. What radio are you using?
RyanH is offline
Old 05-15-2015, 07:07 AM
  #11409
Ryan,
I'm using a DX4R
rdline is offline
Old 05-15-2015, 08:55 AM
  #11410
Jerm13's Avatar
Trader Rating: 36 (100%+)
Stock front end??? Are you using the spindles and carriers that came with the bell cranks or the parts from the kit?
I believe you still have to use the pieces that come with the bell cranks for the correct geometry. Unless that has been changed, it could be your problem...
Also, Instead of running the horn one tooth off, center it. I know a lot of people, as well as I, did that and it will bring your EPA points closer together. For me, I found that the servo will go over center when moving the wheels by hand and cause it to lock up. May also be your issue...
Jerm13 is offline
Old 05-15-2015, 04:58 PM
  #11411
On a Losi 22 2.0 Buggy with a 17.5 Motor what Pinion and Spur gear should I start with
shelby561 is offline
Old 05-15-2015, 05:19 PM
  #11412
68pontiac's Avatar
The manual recommends 35/70 which works out to 4.86:1 final drive.
68pontiac is offline
Old 05-15-2015, 05:41 PM
  #11413
Moderator
mxwrench's Avatar
Be careful and find out which type of stock motor you have before you select your gearing.
Most of the new gen stock 17.5 motors (ie. short stack stators and such) need to be geared considerably lower than 35/70. I think if you are running any of the newer hi revving stock motors you would want to start around 28/70 or 6.075 final drive.
Two years ago, I would have recommended 34/70, but nowadays with the latest stuff on the market, recommending a 35/70 will lead to a cooked rotor. (Don't ask me how I know that. I'll just tell you I found out personally, first hand! lol)
mxwrench is offline
Old 05-15-2015, 05:55 PM
  #11414
I am running a 17.5 Reedy Sonic 540 Mach 2 Motor
Old 05-15-2015, 06:28 PM
  #11415
Moderator
mxwrench's Avatar
Cool, I'd recommend to start with 33/70 (5.154 final drive ratio) with 40-42 timing and gear to temp. Try and keep below 150-160f after 7 mins track time at speed.
mxwrench is offline
