TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 02-01-2015, 01:27 AM
  #10801
Moderator
mxwrench's Avatar
Originally Posted by rage1945 View Post
OK. Let's just say, someone wanted to boil some composite rc parts...how long should this someone boil them for??
Actually boiling is not the solution. To condition the plastic, you DO NOT want to reach the boiling point. Rather stay beneath it. Between 180-200 f. (90-95 C) you want to keep the parts in the water for 120-150 min. at this temp. While this is not as effective as actually conditioning in a humidity/temp controlled chamber, it is roughly 70% effective.
Note: Actually BOILING the part will remove moisture from the plastic, which is not the desired effect.
mxwrench is offline
Old 02-01-2015, 10:50 AM
  #10802
Trader Rating: 14 (100%+)
Digital servos do seem to make a buzzing noise when powered up.
Slimrc is offline
Old 02-01-2015, 11:06 AM
  #10803
LoudOne's Avatar
Trader Rating: 31 (100%+)
Originally Posted by skeasor View Post
What turn motor are you running? The 22 2.0 comes with 2 spur gears (70 for 13.5T and 17.5 and a 78 spur for motor turn < 13.5) I'm running a 13.5T, 29T pinion and 70T spur) Depending on the track layout I've ran everything from a 26t pinion to a 30t pinion. (Wouldn't run the 30t pinion again as the motor was getting way too hot)
I have a Reedy Mach 13.5 sensored.. 29T pinion? I ride on an indoor track.. carpet.. so I think that would be way too fast.. I like to keep the pinion at 18-19 tooth, so what should the spur count be (13.5 turn engine)?
LoudOne is offline
Old 02-01-2015, 11:57 AM
  #10804
Thanks. I won't be doing this, but good to know. I believe I was the one at fault and wrenching the front tower down too much.
rage1945 is offline
Old 02-01-2015, 12:03 PM
  #10805
Mikeand22's Avatar
Trader Rating: 29 (100%+)
Here is a link about gearing. It really helped me out so hopefully it will help you out as well.
http://www.petitrc.com/Tech/UnderstandGearingRatio/
Mikeand22 is offline
Old 02-01-2015, 12:13 PM
  #10806
I run mod. on a small tight indoor carpet track with a 13.5 and almost always run 78/24. I run some boost too, but the amount I run depend on the layout and straightaway length. The book suggests running a 26 tooth pinion for a 13.5, and most guys run a 70 tooth spur in stock ( no timing). I also have a fan on my motor to keep things cool.
rage1945 is offline
Old 02-02-2015, 04:37 AM
  #10807
skeasor's Avatar
I never tried running the 78 tooth spur with a 13.5 motor. I use the 70 tooth spur and run anywhere from 26-29 tooth pinion with very little end bell timing.
skeasor is offline
Old 02-02-2015, 06:56 AM
  #10808
I have broken a couple of shock towers from 2011 to now! Boiling them wont help, just replace them once a year and you should not have any problems.
synap2012 is offline
Old 02-02-2015, 07:59 AM
  #10809
I just bought a used 22 1.0 with 2.0 upgrades and the question I have is it has black springs front and rear. Idk if the kit spring where just black and really the red / yellow it calls for. There's not a black rear spring and the front feels really soft for a black. Thanks .
Wg931 is offline
Old 02-02-2015, 10:00 AM
  #10810
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
You are better off running the parts through 1 or 2 cycles in the dish washer
Frank Root is offline
Old 02-02-2015, 12:57 PM
  #10811
Davidka's Avatar
Trader Rating: 83 (100%+)
All of the springs are black. There should be a small paint mark on the coil near one end of the spring. Look closely and you should be able to see it.
Davidka is offline
Old 02-02-2015, 03:40 PM
  #10812
Ant73's Avatar
Can anyone direct me to the part numbers for the normal and titanium 55mm x 3.5mm turnbuckles for the bell crack steering system? I can't find them. Lots of kits and after market but can't find TLR pairs.... Cheers.
Ant73 is offline
Old 02-02-2015, 09:54 PM
  #10813
TLRacing
Frank Root's Avatar
55mm HD turnbuckles are not sold as pairs, but are available in the 22-4 stock turn buckles kit (since the 22 2.0 comes with non-HD turnbuckles). http://www.tlracing.com/Products/Def...odID=TLR234022
55mm HD Titanium Turnbuckles are available in the 22 2.0 Titanium Turnbuckles kit. 4x 55mm and 2x 50mm. http://www.tlracing.com/Products/Def...odID=TLR334016
Old 02-02-2015, 10:20 PM
  #10814
Razorbelly's Avatar
What's the story on carbon fiber front towers for the 22 2.0? With all the breakage of the plastic ones. Are the carbon fiber towers a good option?
Razorbelly is offline
Old 02-02-2015, 11:24 PM
  #10815
You should try it...you might like it! Lol. Works well on our very small, very tight carpet track in open class. Their is no stock class to run here right now, but if I ran it, I would opt for that gearing combination.
rage1945 is offline
