TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 01-22-2015, 03:57 PM
  #10681
Jerm13's Avatar
Trader Rating: 36 (100%+)
Longer wheelbase would be my first adjustment. Then possibly longer rear camber links, then more rear toe.
Jerm13 is offline
Old 01-22-2015, 05:23 PM
  #10682
Mudcat981's Avatar
Originally Posted by pyroMIKE View Post
Seems that the rear end pivots around quicker than I like in 180 turns. What could I do to get the rear end to plant-pivot slower in the corners.
Lengthen the rear camber links. positions 1-b
Set the rear shocks at a steeper angle, tower position 1, arm- outside.
Are you running a gear diff or ball diff? If a gear diff, change to a ball diff. Once adjusted if still a little quick you can loosen the diff by 1/8 or 1/4 turn max.
I would also start with Dakota Phend RM setup:
http://www.tlracing.com/ProdInfo/Fil...ning_setup.pdf
This setup has 2.5 anti-squat, I prefer the 3.5 anti-squat.
Mudcat981 is offline
Old 01-23-2015, 06:49 AM
  #10683
Lacking forward traction running on carpet... mid motor, gear diff, running slicks as control tyre. Before I get to it are these suitable options;
- increased front droop
- thicker oil in gear diff (now feels like there is not much oil left actually)
- softer rear suspension
- reduced anti squat
Did I get things right, anything else, i.e camber link mod?
Pellefa is offline
Old 01-23-2015, 08:34 AM
  #10684
gticlay's Avatar
Trader Rating: 14 (100%+)
"add weight" like the brass pivot under the motor. You may have already done this but you didn't say.
gticlay is offline
Old 01-23-2015, 12:31 PM
  #10685
swimmerx7's Avatar
congrats to me, read the last 107 pages over 2 weeks and now i'll allow myself to buy the kit, hopefully i'll remember everything i read.
most importantly include the bellcrank steering from the beginning, with a Spektrum S6040 standard size = servo horn straight up and down, steering linkage 30mm
pretread tierods all the way in then back out to size
thanks to Frank Root, you sir are the single biggest reason why i'm going losi 22, keep up the good work
swimmerx7 is offline
Old 01-23-2015, 02:42 PM
  #10686
vr6cj's Avatar
Trader Rating: 124 (100%+)
So I spy a newer battery setup and brace it looks like a hybrid of the rm and mm.
If posted before sorry.
vr6cj is offline
Old 01-23-2015, 03:21 PM
  #10687
MasiisaM's Avatar
Thats interesting...looks like he cut the MM tray to fit the ESC on there..looks like it still pivots to get the battery out and use the RM battery holder and block.
Looks like the front caber block is different..
Coating on shock shafts
Pod weights are gone replaced with brass side weights
MasiisaM is offline
Old 01-23-2015, 04:13 PM
  #10688
Mudcat981's Avatar
Default Update on Frank Root - Reedy Race
Frank is giving it his best but he is running about 5-10 seconds slower than the top guys. His heat has the top qualifiers which makes it tough. These guys are fast, some as fast as the Factory Invitationals.
Franks standings After 2 rounds:
2WD - 37 of 100
4WD - 20 of 97
Good Luck!
Old 01-23-2015, 05:36 PM
  #10689
easy e's Avatar
Trader Rating: 28 (100%+)
That is the front camber block from the 22SCT, it makes the inner ball stud sit higher without any washers. I do not know the exact height, guessing 2-3mm..
easy e is offline
Old 01-23-2015, 05:38 PM
  #10690
easy e's Avatar
I almost think these look like the weights he is using..
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-maifield-brass.jpg
easy e is offline
Old 01-23-2015, 06:02 PM
  #10691
Mudcat981's Avatar
Frank had a great 3rd Round
2WD Open - Frank had a good run finally, finished 3rd, but 6 seconds behind Kevin Motter.
4WD Open - Frank finished 2nd, .2 seconds off 1st
Final Friday night standings:
2WD - 5th
4WD - 11th
Awesome job FRANK!!!!
Old 01-24-2015, 07:19 AM
  #10692
Mikeand22's Avatar
Trader Rating: 29 (100%+)
Does anyone use the TLR aluminum diff nut? If so, is it worth while or are the stock plastic ones the way to go? Thanks for the help!
Mikeand22 is offline
Old 01-24-2015, 09:55 AM
  #10693
Trader Rating: 22 (100%+)
Wonder what chassis Maifield is running? Under side shot shows no hole for the little 2/56 screw that goes into the anti-squat block. New battery hold down looks good!
RandyJones is offline
Old 01-24-2015, 02:04 PM
  #10694
Davidka's Avatar
Trader Rating: 83 (100%+)
Also appears to have sway bar mounts (not in use).
Nah, the gen II plastic one is all that's needed.
Davidka is offline
Old 01-24-2015, 07:35 PM
  #10695
Kewlbug's Avatar
Trader Rating: 63 (100%+)
I was wondering same thing. 1.0 chassis? He does like a heavy car apparently.
Also the track looks almost not tight enough to warrant the -2.5
Kewlbug is offline
