TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Old 01-09-2015, 10:35 AM
  #10501
skeasor's Avatar
Anyone have any tips changing the anti squat? I generally loosen the screws that go into the hinge pin brace/transmission and remove and add a different shim but putting the shim back in place can be tricky...I found that a nail file usually works pretty good. Just wondering if anyone else had any tricks?
(mid motor without removing the motor)
skeasor is offline
Old 01-09-2015, 06:19 PM
  #10502
I believe that if you are changing anti squat you also need to change the plastic that is in the pivot block. It's not just good enough to change the shim only. They work in pairs,
That aside, to get the shim to stay in I usually just hold the buggy up and use gravity and/or a small hex wrench to help it in place
brew99 is offline
Old 01-10-2015, 08:47 AM
  #10503
Trader Rating: 23 (100%+)
What Springs come in the kit with a 22 2.0?
impson is offline
Old 01-10-2015, 09:34 AM
  #10504
brian cox's Avatar
Trader Rating: 68 (100%+)
red front low freq---yellow rear low freq
brian cox is offline
Old 01-10-2015, 09:58 AM
  #10505
Davidka's Avatar
Trader Rating: 83 (100%+)
What TLR springs make a goo substitute for the Kyo gold front?
Davidka is offline
Old 01-10-2015, 10:25 AM
  #10506
Jake S's Avatar
Trader Rating: 67 (93%+)
closest would be Non-low freq green.
green front (3.5) being slightly stiffer. blue front (3.8), so a good bit higher. silver front (3.2) is slightly softer.
i run the avid red front (3.33) as its very close to the kyosho gold ( 3.34 - based on commonly used chart )
Jake S is offline
Old 01-10-2015, 04:21 PM
  #10507
Jason's Avatar
I thought the same thing until I saw Jason's car run on a pretty low grip track last week. His was the best running car at the track (out of about 40 in the class). Ask him but I believe he's using a setup close to the Mayfield version with the only added weight being the brass pivot block.
Thanks dude. Glad I could shed some light on you mid motor/MED traction thoughts.
I'm pretty much running a maifield MM setup with some tweaks. I actually got the entire setup from a local sponsored driver. My front shocks are 2x1.6 pistons with 30wt oil and silver springs.
Jason is offline
Old 01-11-2015, 05:12 AM
  #10508
Wrong post
h.lourenssen is offline
Old 01-11-2015, 07:41 AM
  #10509
Swaybarz's Avatar
Is there a body that has enough room to run an ESC fan when mounted on the mm battery lid?
Swaybarz is offline
Old 01-11-2015, 08:19 AM
  #10510
jgroenhof's Avatar
It looks like the small plastic part (block) controls the attitude of the tranny.
For example if you ran 3 shims and the 1 block the front of your trans would sit very high, this in turn would raise your outdrives. The 3 block would keep the trans down where it should be. Does the block have a name?
jgroenhof is offline
Old 01-11-2015, 09:20 AM
  #10511
skeasor's Avatar
I doubt it. I believe the stock body provides the most room.
skeasor is offline
Old 01-11-2015, 09:31 AM
  #10512
The pro line body does, it has a raised up section in this area, I'm running novak impact with fan
Mxr33 is offline
Old 01-11-2015, 03:55 PM
  #10513
Default removing slipper for stock setup
Some of the stock buggy guys at my local track have removed the slipper entirely for their stock setup 2wd buggy. I run a losi 22. What impact will this have and what exactly do I need to do to convert to "no slipper" set up. Thanks in advance for your help!
Cojex1 is offline
Old 01-11-2015, 04:13 PM
  #10514
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 197 (100%+)
Arrow Direct Mount
I run it, gave me more bottom end quicker down low. Was able to clear jumps with ease . When traction is Med/High. If low traction it is a little tough but that what throttle control is for! Here is what I use> http://www.exotekracing.com/22-direct-spur-mount/
XXXDad is offline
Old 01-11-2015, 08:02 PM
  #10515
Can the Aka premounts be ran on 22 2.0?
Is that a bad idea? Pros/ cons?
impson is offline
