TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 12-22-2014, 10:52 AM
  #10216
Originally Posted by brew99
Is that 32mm center-center, or ends of the eyelets as measured in the manual? I'm finding similar things with the 22T needing to be much longer than suggested, and will be doing the bell crank on the buggy here soon also
31.949 is where i ended up end to end
racer888 is offline
Old 12-22-2014, 12:07 PM
  #10217
Jake S's Avatar
Trader Rating: 67 (93%+)
Originally Posted by jpcopeland1
30MM rod length per Frank Root.
+1 this is exactly where i am at.
Servo horn vertically centered.
my airtronics servo would not have a "verticle" setting as it was about half a tooth off in either direction. so given the choice always go towards the left side 'drivers side' (in usa anyway).
if your settings are where they should be (both steering turnbuckles equal length, servo horn centered properly, and steering rod length correct) your epa should be within 5 on left and right at max.
also i have noticed that if it seems like your servo doesnt want to center properly at the track, try replacing your servo mounts - the plastic does wear out if your removing them a bunch.
Jake S is offline
Old 12-22-2014, 01:11 PM
  #10218
hoyt1967's Avatar
Trader Rating: 36 (100%+)
Any recommendations on what to adjust to get more low speed steering? Seemed to really be pushing on me last weekend. Just looking for some guide lines to improve this. Running MM setup, electronics in front of shorty pack. Stock buggy class.
hoyt1967 is offline
Old 12-22-2014, 01:21 PM
  #10219
Jake S's Avatar
if you havent already.... the tlr bellcrank system. if you already have those, try alittle toe out in the front.
Jake S is offline
Old 12-22-2014, 02:50 PM
  #10220
30 Wt front 1.5 pistons . Silver springs shock location 2 and middle on 1.0 arm. 3 mm outer link 2 mm inner camber link
27.5 wt rear white spring 1.6 piston. ..0 hole and inside hole on rear arm. Low mount ball stud on inner link and 2 mm on outer link in the D position. Speedo on battery tray . I run 17.5 car is dialed
Rcfun96 is offline
Old 12-22-2014, 05:17 PM
  #10221
hoyt1967's Avatar
I have the bellcrank system installed.
hoyt1967 is offline
Old 12-22-2014, 06:38 PM
  #10222
For low speed steering a noticeable effect is TOE OUT! I also notice lengthening the wheel base helped my low speed cornering too
A few other things to try for more steering
On power push problem try = limit droop in front, more anti squat in back, softer front spring
Off power push problem try = add some rear droop
I am typically running medium grip clay tracks
synap2012 is offline
Old 12-22-2014, 06:48 PM
  #10223
hoyt1967's Avatar
Ok that is some good info. So as far as toe setting goes, how much is too much on toe out? And how much does a guy start with, 1/2 turn on each tie rod? Other than the low speed steering the car handled very well. Was a high grip track.
hoyt1967 is offline
Old 12-22-2014, 07:20 PM
  #10224
Jerm13's Avatar
1/2 turn is a good starting point. Careful not to do too much. Usually 1-2* is all you need.
I measured it out one time... about a year ago.
With 4 rib fronts, car set up at race weight, I was at 3/16 of an inch wider at the front of the tire than the rear. Digital protractor said it was a 2.3 degree average. This was the high and low measurement to account for the slop in the steering.
Happy hunting...
Jerm13 is offline
Old 12-22-2014, 10:51 PM
  #10225
Trader Rating: 24 (100%+)
Finished up my kit, can't wait for the first drive!
justinco is offline
Old 12-23-2014, 01:12 AM
  #10226
Jake S's Avatar
quick question... looking at my brass anti squat it seems like the trans doesnt "key in" like a pic i saw on wheeler's facebook of his in his sct... is that just because different anti squat? (im running 2-deg in mine - looks like 0-deg in his sct)
Jake S is offline
Old 12-23-2014, 04:48 AM
  #10227
skeasor's Avatar
What adjustment do you recommend do add more droop?
skeasor is offline
Old 12-23-2014, 05:22 AM
  #10228
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Exclamation
Unscrew the shock rod end/eye (1-2 full turns) < To add droop... also don't forget to run a short camber link in the front to get more steering!
XXXDad is offline
Old 12-23-2014, 05:50 AM
  #10229
skeasor's Avatar
Thanks!
skeasor is offline
Old 12-23-2014, 01:50 PM
  #10230
easy e's Avatar
Trader Rating: 29 (100%+)
I slept on the -2.5mm chassis, out of stock ETA April 28th lol ... my bad
easy e is offline
