TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 12-03-2014, 07:23 AM
  #9946
Trader Rating: 166 (100%+)
Originally Posted by hoyt1967
I'm really confused on the steering vs. spindle choices. So I'm running an exotec rack setup, would I be better off switching to the new bellcrank spindles? And what is the concern with choosing the right spindle? Is it loosing your lock to lock ability? As long as you run a 4mm spindle that goes lock to lock is that the key? Sorry, I'm just in left field on this.
You must use the spindle that comes with the bell cranks. It was redesigned for the 22SCT 2.0 and use of any other spindle will not get you full lock. I witnessed this first hand last night when we tried to put a set on my brothers 22SCT 1.0 and didn't use the correct spindles or caster blocks. Nowhere near full throw in either direction and he had very little steering. I asked him if he had used everything that came in the package and he said no. Went back and put all of the right stuff in, and presto. Full lock both directions. Also be aware that if you are putting this on an original 22, you need 22 2.0 caster blocks. I would switch to the bell cranks as my Exotek rack was pretty sloppy and the TLR version does not have this issue and was engineered by TLR themselves. Also there is debate as to whether the Exotek rack has the right geometry. For things like this I don't count on after-market companies to get it right.
jpcopeland1 is offline
Old 12-03-2014, 07:46 AM
  #9947
hoyt1967's Avatar
Trader Rating: 36 (100%+)
Thanks, that helps alot.
hoyt1967 is offline
Old 12-03-2014, 07:54 AM
  #9948
RedBMaster's Avatar
Originally Posted by urluzn
There the same as savox or futaba.
That doesn't seem quite right as I couldn't use my Savox servo with the Exotek bell cracks.
RedBMaster is offline
Old 12-03-2014, 10:11 AM
  #9949
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by BLbound
Does anyone know who has the TLR brass rear pivot in stock? Thanks in advance!
Pacific Coast Hobbies - They are on eBay
Originally Posted by RedBMaster
I think JP Richards runs Xpert servos. Could someone check with him?
Or Frank, how do you determine how much spacing to use? I figure it needs at least the 1mm shim.
You want the servo horn/ball stud centered in the opening of the right front bulkhead loop.
Frank Root is offline
Old 12-03-2014, 10:55 AM
  #9950
RedBMaster's Avatar
Perfect, thank you Frank!
Old 12-03-2014, 11:01 AM
  #9951
hoyt1967's Avatar
Can I use a Savox with the new TLR bellcrank setup?
hoyt1967 is offline
Old 12-03-2014, 11:04 AM
  #9952
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Jason Synder posted a video of the savox and the new bell cranks...so I would say yes....
Wildcat1971 is offline
Old 12-03-2014, 11:23 AM
  #9953
RedBMaster's Avatar
Yes, the TLR bell cracks use normal servo spacing. You could use it with the Exotek bell cracks as well, but you'd need to buy their modified servo mounts. Which cost more than the whole TLR bell crack kit!
I put my Savox servo in my 22-4 and got the Xpert servo to go with the Exoteck bell cracks while I waited for the TLR ones. The TLR bell cranks use kit servo spacing, and Xpert servo spacing isn't listed in the manual. That is why I was asking. Hopefully that makes more sense!
Old 12-03-2014, 11:46 AM
  #9954
I have the xprt LP servo in mine. I used a .5mm spacer and the alum TLR servo horn.
Old 12-03-2014, 12:05 PM
  #9955
Yes. My brother ended up using 2mm spacers but it works perfectly.
Old 12-03-2014, 12:07 PM
  #9956
Anytime.
Old 12-03-2014, 12:54 PM
  #9957
BLbound's Avatar
Trader Rating: 27 (100%+)
Thanks Frank! I'll check with PCH again.
BLbound is offline
Old 12-03-2014, 01:18 PM
  #9958
Yes, I used a 1256 and it fits perfect.
rippen is offline
Old 12-03-2014, 02:08 PM
  #9959
hoyt1967's Avatar
Great guys, thanks much for the info. I did order a new set to replace my exotec rack. So my only other concern, the new TLR bellcrank kit, is it plastic?? I seem to break alot of things, so will I need spare bellcranks?
hoyt1967 is offline
Old 12-03-2014, 02:32 PM
  #9960
Originally Posted by Sodakota
I run a gear diff on carpet and I've settled on 5k. 7k I don't get the rotation I like and 3k made my car kinda squirlly on power coming out of corners. Also if your track allow pinpoints use them they are the only tire to use trust me.
Tires is slicks that all we can use. jconcepts
FLYINGBRIAN is offline
