TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 12-02-2014, 02:06 PM
  #9916
onadcr74's Avatar
Hey guys, I FINALLY got my 1.0 converted completely to the 2.0 in mid motor config last night with the -2.5 chassis. I couldn't stop looking at it, lol! Anyway, the one thing that I noticed was that I thought that the servo was supposed to lay flat in the milled out part. It seems to sit lower but there is maybe a mill to a mill and a half of space between the bottom of the servo to the chassis. Are the servo mounts different from the 1.0 to the 2.0?
onadcr74 is offline
Old 12-02-2014, 03:04 PM
  #9917
skeasor's Avatar
Originally Posted by easy e
I went with a shorter screw to use in the underside of chassis to mount the tranny, not sure what size, long enough but shorter .. haven't had any problems
and for the rear shock mounts in the a-arm I used a 3mm cap head screw, uses a 2.5mm hex wrench
Yea, I'm running a cap head screw there too now. I haven't had a problem since.
skeasor is offline
Old 12-02-2014, 03:46 PM
  #9918
Trader Rating: 166 (100%+)
No.
jpcopeland1 is offline
Old 12-02-2014, 04:55 PM
  #9919
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
what front springs are you guys using for high bite indoor clay in MM? Seems Dakota and Ryan are using kyosho gold. I have some heavier AE springs and Avid purple fronts I can use.
Wildcat1971 is offline
Old 12-02-2014, 05:49 PM
  #9920
I'm gonna try my AE yellow springs just about the same spring rate as the kyosho gold. Let you know they work on thursday.
racer888 is offline
Old 12-02-2014, 06:13 PM
  #9921
yeah, the avids are about 3.65. might try them but, that seems soooo stiff and I might want less spring rate because I am running 17.5 and no added weight
Old 12-02-2014, 06:57 PM
  #9922
Jake S's Avatar
Trader Rating: 67 (93%+)
if you have avid red fronts, they work really well, and are alot closer to the kyosho gold buggy front. if not an ae gray is pretty close too.
Jake S is offline
Old 12-02-2014, 07:19 PM
  #9923
onadcr74's Avatar
Originally Posted by jpcopeland1
No.
OK, great! Is the servo supposed to be suspended a bit above the chassis or should it fit flat down inside the milled part?
onadcr74 is offline
Old 12-02-2014, 07:36 PM
  #9924
Jerm13's Avatar
Trader Rating: 36 (100%+)
Flat.
Do you have anything under the servo like double sided tape, or did the mounting screws cause it so shift a bit?
I was messing around one day and took the side pods off and there was a little space between the mount/brace and the chassis. Took me a minute to realize there was a piece on the side pods that slips between the chassis and brace. You do have the side pods on correct??
Jerm13 is offline
Old 12-02-2014, 08:23 PM
  #9925
Default 22.2.0 mid motor
I will be runing car on carpet with gear diff.what fluid should I start with.thanks.
FLYINGBRIAN is offline
Old 12-02-2014, 08:28 PM
  #9926
onadcr74's Avatar
Originally Posted by Jerm13
Flat.
Lol, yes, I do have the side pods on! No, I don't have any servo tape under it. I'll have to check it over again. I very well coulda made a mistake somewhwere. I was excited and in a hurry to get everything mounted up to the new chassis and get it in mid motor configuration. I've been wanting to get it to this point for soooo long, it is so bad ass just sitting there, lol! Hey thanks for taking the time!
onadcr74 is offline
Old 12-02-2014, 08:46 PM
  #9927
I run a gear diff on carpet and I've settled on 5k. 7k I don't get the rotation I like and 3k made my car kinda squirlly on power coming out of corners. Also if your track allow pinpoints use them they are the only tire to use trust me.
Sodakota is offline
Old 12-02-2014, 09:00 PM
  #9928
I found golds to make the front hyper sensitive at SRS. Use what feels best for you im at silver fronts on mine but still testing.
Gitsum is offline
Old 12-02-2014, 09:17 PM
  #9929
RedBMaster's Avatar
What is the recommended spacing for Xpert servos. I'm moving to the TLR bell cracks from the Exotek ones and want to get optimal spacing for the shorter chassis.
BTW, I have the pics for my mm shorty setup using stack parts, but I haven't been able to get to my pc to convert and upload them.
RedBMaster is offline
Old 12-02-2014, 09:40 PM
  #9930
(P.s. use all the parts) in the bell crank kit unlike me!!!!!!lol
No wonder the rear motor buggy was a hand full the last time I was at thunder!!!! Lol
S.TRIPP77 is offline
