TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 12-01-2014, 12:19 AM
  #9856
I got a dumb question so don't laugh.
The got the new bell crank system. Am I supposed to use the spindles that come in that kit or use the stock 22 2.0 spindles???
The reason I didn't is cause I thought I read that the spindles was the same but I just saw a spindle from a main hobbies and it said that these was to be used with the bell crank and not the slider??
These parts http://www.amain.com/team-losi-racin...-crank/p300495
S.TRIPP77 is offline
Old 12-01-2014, 03:53 AM
  #9857
skeasor's Avatar
[QUOTE=Jerm13;13690145]
Originally Posted by skeasor
What body are you running and where are the clearance issues. I have only run the kit sloped window body. Want to get a Losi cab forward here in the future...
I'm running the TLR cab forward body. The rear of the body doesn't want to clear the battery on either side. Maybe the body that vr6cj is using has longer sides.
skeasor is offline
Old 12-01-2014, 04:07 AM
  #9858
Errokk's Avatar
Gotta use the ones with the Bellcrank kit.
Errokk is offline
Old 12-01-2014, 04:23 AM
  #9859
Lenman73's Avatar
I just finished my build with the -2.5mm chassis last night and running midmotor with the waterfall and waterfall battery strap. Is it normal for a shorty pack to fit extremely tight in there ?
Lenman73 is offline
Old 12-01-2014, 04:24 AM
  #9860
Trader Rating: 27 (100%+)
Yes it will be tight.
RandyJones is offline
Old 12-01-2014, 04:41 AM
  #9861
skeasor's Avatar
Yea, I always feel like I'm going to break something when I put the battery in.
skeasor is offline
Old 12-01-2014, 04:44 AM
  #9862
Lenman73's Avatar
Thanks. Wanted to make sure I didn't screw something up. Lol
Can't wait to try it this weekend.
Lenman73 is offline
Old 12-01-2014, 05:05 AM
  #9863
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Wow I was super happy with my Two 22 buggy's with the new -2.5 chassis .
Loved them feeling so smooth turning and planted.
Running MM Mod.>I also used 4* rear pivot because I run outdoor .
Let me tell you, this is the trick to TRACTION outdoors with the right tire combo. I also feel I need to use a more aggressive tire up front because traction is so high and it will start to push I used M3 holesot front and M4 rear. This is for outdoor or loose indoor.
XXXDad is offline
Old 12-01-2014, 05:26 AM
  #9864
I'm debating getting the shiny pucks or the universal joint driveshaft set. Can anyone tell me what they think are better and why?
TLRbigdog is offline
Old 12-01-2014, 05:57 AM
  #9865
Stock or mod class?
racer888 is offline
Old 12-01-2014, 06:57 AM
  #9866
Lenman73's Avatar
What did you guys use to keep the battery from sliding side to side ?
Lenman73 is offline
Old 12-01-2014, 06:59 AM
  #9867
It won't move side to side. It's pretty locked in.
Old 12-01-2014, 07:07 AM
  #9868
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by racer888
Tried searching can't find my answer so sorry if it's been beat to death but... I'm looking to replace my 17.5 motor with a new one and looking for some insight in what people are running 17.5 only and what kind of gearing/end bell timing
Thanks in advance.
people run whatever motor they like. Timing and gearing arevery subjective. I know a guy that built a dyno to find the optimum "power" and efficiency for his 17.5. I am done giving motor advice. I have seen $30 motors beat $150 motors. When it comes right down to it, people buy their favorite brands of buy cheap. I dont subscribe to the motor of the month crap.
Wildcat1971 is offline
Old 12-01-2014, 07:12 AM
  #9869
I am looking to give MM another shot in 17.5 stock. I have the bell cranks, but not the -2.5, and I have no plans to buy the new chassis. I run on medium to high grip. I might drill the "0" hole just for tuning purposes, but I have no desire to add more weight to the car. We run clay slicks. I am looking for a "balanced" starting setup. I was thinking maybe Maifields, but without all of the weight. thoughts?
Old 12-01-2014, 07:14 AM
  #9870
skeasor's Avatar
Mine will only move from side to side if I force it to and even then it barely moves. If it's moving that much you could always use foam spacers .
skeasor is offline
