TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-24-2014, 08:38 AM
  #9736
Someone teach me on the the shims that are on the spindle to raise and lower the spindle.what does it do.
S.TRIPP77 is offline
Old 11-24-2014, 08:55 AM
  #9737
shadowracer24's Avatar
Lowering the spindle will help you gain a little more steering on entry and raising it will induce a little push. That's what I found on mine anyway.
shadowracer24 is offline
Old 11-24-2014, 10:06 AM
  #9738
skrichter's Avatar
From Schelle Racing website:
Kurt "Coach" Wenger Axle Height Tuning Tips:
Axles Up: (Thin on top/ Thick on bottom) Max Steering and Corner Speed. Sometimes hard to drive.
Axles Middle: (Middle bushing both sides) Standard, Neutral Feeling.
Axles Down: (Thick on top/Thin on bottom) Easy to drive, Reduced entry steering, stable in bumps.
skrichter is offline
Old 11-24-2014, 11:58 AM
  #9739
Bivens's Avatar
I use it as a quick droop adjustment...although there is a little more going on than just that with this adjustment. (shock length is the true droop adjustment for 1/10).
I'd love to have droop screws for all new losi 1/10 cars in the future......just asking...
Shims on top = similar to reducing droop
Shims on bottom = more droop
And, the roll center will change slightly.....
Bivens is offline
Old 11-24-2014, 05:40 PM
  #9740
I would like to see droop screws also.
Old 11-24-2014, 06:56 PM
  #9741
Kewlbug's Avatar
Trader Rating: 63 (100%+)
Originally Posted by Jerm13
Also helps with forward bite too.
I didn't feel like spending $15 on a set, so I used the spacer/washer that goes between the axle and inside of the hub. Just moved it to the outside. Not a whole .75 MM but comes out to .67MM. Not bad and free if you don't want to spend the cash to try out.
I am still unclear, can someone explain running the STD rear hex vs the +.75 hex.
Sorry if this is already covered. My 22 2.0 came w the .75 but I'm curious about any benefit to going w STD.
Our track is kindof a wierd slippery clay.. gets good 5 min after watering but 10 min after water starts getting dusty and slippery.
Kewlbug is offline
Old 11-24-2014, 08:38 PM
  #9742
racer x 1's Avatar
Trader Rating: 27 (100%+)
Can anyone share a good mid motor set up for OCRC (med to high bite indoor clay)? Im seeing a lot of variations in shock packages
racer x 1 is offline
Old 11-24-2014, 08:39 PM
  #9743
seth556's Avatar
Trader Rating: 43 (100%+)
This isn't what the other replies support but it's what I've found through testing and thinking about the physics of it.
A more narrow rear end will lock it in but won't be as stable. A wider rear end will be a little more loose and as a result the car will rotate better, it'll also be more stable.
A wider car should be easy to think about why it's more stable. Think about a stadium truck and how stable it is. Spread your feet farther apart and you'll feel more stable than if your feet were touching.
As far as a narrow car being more traction, think about putting your hand over a soda can and trying to crush it (without getting a wind up). Is it going to be easier to crush when it's less than a foot away, or easier if it's at arms reach?
You are also changing how far the wheel is from the hinge pin, but I think that's less noticeable of a difference. I think this gives more forward traction. Say you moved the hinge pin on the arm and used a wider hex, I think you'd have more forward bite.
seth556 is offline
Old 11-24-2014, 08:43 PM
  #9744
anyone have a TLR334018 rear hinge pin brass brace For Sale? I missed my window and thought it was the same as the rocket-rc one I have.
David Alberico is offline
Old 11-24-2014, 09:01 PM
  #9745
RedBMaster's Avatar
Personally I run Ryan's setup, but I've altered the shock package to better handle the nuances of my track. It looks like there are three setups for that track on the TLR website. So you want to look at setups based and driving style. Mine is more Ryan's and my dad's is closer to Frank's. Which ever you choose, know that this is just a starting point. You'll want to customize the setup to fit you personally. This is why you see minute changes in setup people are posting.
RedBMaster is offline
Old 11-24-2014, 10:32 PM
  #9746
racer x 1's Avatar
Thanks redb! I saw those and was posting because i cant say i have seen those pistons being used or even tslked about on any other buggy. Im particularly curious how the 3x1.3 and 3x1.4 act over the 2x1.6 combo.
Old 11-25-2014, 07:20 AM
  #9747
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Questions?? ?
What do you think is different? The weight/ of the rocket part is 36g and the TLR is 35g
XXXDad is offline
Old 11-25-2014, 08:18 AM
  #9748
seth556's Avatar
Here's the brass block, they also have the chassis and bell cranks. https://www.superiorhobbies.com/stor...%3A+22%2F2%2E0
seth556 is offline
Old 11-25-2014, 09:36 AM
  #9749
kdeleon's Avatar
Just a slight clarification, the TLR part is 35 g over the stock part and not total weight. While the rocket part is 32 g above the stock part for a total of 36 g.
So by the rocket rc page that would mean that the TLR part is 39 g total, even though TLR does not explicitly say. The TLR part seems to be 3 g heavier.
kdeleon is offline
Old 11-25-2014, 09:41 AM
  #9750
skeasor's Avatar
Has anyone ever tried putting something like this on the rear end of the 22 2.0?
http://www.amain.com/traxxas-revo-la...balls-12/p3101
I somehow always strip ball studs out of the rear bulk head and I'm looking for ideas.
skeasor is offline
