TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-04-2014, 06:19 PM
  #9316
Originally Posted by Jake S
no. but its a better option to use your credit then to get anything castle.
Not a Castle fan? I've heard nothing but good things about them...Im no fanboy of anything but I'm just trying to build the best car for the money, thats all
alexanderb33 is offline
Old 11-04-2014, 06:38 PM
  #9317
seth556's Avatar
Trader Rating: 43 (100%+)
Castle is great for a Slash, but not a racing buggy. Get a low profile servo, pretty much any one available will be good for the buggy.
seth556 is offline
Old 11-04-2014, 06:41 PM
  #9318
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
castle is bashing stuff and... the sidewinder stuff seems to fail a lot.
Wildcat1971 is offline
Old 11-04-2014, 06:52 PM
  #9319
Jake S's Avatar
Trader Rating: 67 (93%+)
best car for the money would be the turnigy motor and esc.
if you have any thoughts about running mid motor on it, i would get a http://www3.towerhobbies.com/cgi-bin...?&I=LXDEAY&P=7. alittle more money, but it will make your life easier with the mid motor car. i currently run a full size servo in my mid motor car, but i also have a small rx.
if your only running rear motor, the previous hitec i linked would be a good servo.
the other option if you run a full servo and have space limitations due to your rx is that you can mount it to the bottom of the servo to free up some electronic space in mid config.
Jake S is offline
Old 11-04-2014, 06:55 PM
  #9320
Ok, I think I'll go with an 8.5T TrackStar then. Is it better to get the Turnigy ESC in the combo or get that HobbyKing X Car 120A ESC separately with the TrackStar motor?
I'll go with that HiTec servo you linked as well
Old 11-04-2014, 06:58 PM
  #9321
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Jerm13
Its a magical and mythical creature that can not be tamed or captured that when killed, bleeds glitter
Nah, its the bell cranks like Frank said
Lol, my 2.0 sct has that in. Kit so it's magically delicious!!!
TommyBlazin is offline
Old 11-04-2014, 07:39 PM
  #9322
Errokk's Avatar
Hey guys,
I just got a TLR 22 2.0 for very cheap, however this will be my first build and I've only driven RTR kits in the past. This is what I've found so far, and I'm trying to stay on a relatively low budget. Please let me know if there is anything you would swap for around the same price. Also could you let me know if this stuff is compatible? I just dont really know what im doing and I feel lost!
Castle Creations Sidewinder SV3 motor/ESC combo 4600 kV - $110
Savox 1257 servo - $67
Spektrum DX2e Radio System (transmitter and receiver) - $59
Does this stuff look good? I'm trying to get into racing, but I dont have a ton of money to blow.
Also, I am totally lost when it comes to the motors...should I get a higher kV? I have a bunch of 2S LiPo's that I will be using.
Thanks a lot in advance for everyone's time and help.
Do not buy that motor and speedo!
For relatively similar price you can buy a Speed Passion Reventon Pro and motor combo for around $140ish shipped on fleabay, I'd start with a 10.5 turn. A 6040 spektrum servo will be similar in price also. Pm me if you need some help finding anything.
If you buy the trackstar, get the 120 xcar speedo and any of the trackstar motors are good also at a really light budget price. Make sure it's a sensored motor and esc!
Errokk is offline
Old 11-04-2014, 07:44 PM
  #9323
LOL, I would not touch their current generation motors or ESC's. When HW made their esc's they were much better. And $140 is 2x the $70 for the turnigy. I would take that turnigy motor over the SP motors any day.
Old 11-04-2014, 07:49 PM
  #9324
Wildcat1971, would you pick the HobbyKing X Car 120A ESC or the Turnigy ESC that comes with the Turnigy TrackStar combo...they'd be pretty much the same price
Old 11-04-2014, 07:56 PM
  #9325
Errokk's Avatar
I run the HW made version speedo without any issues in 2wd and 4wd buggy. The old 1.0 version. You can still find them on Fleabay. I second you on the trackstar motors.
The xcar esc is a HW 120 clone and imo is far better than the newer turnigy.
Errokk is offline
  #9326
The turnigy because it has solder posts
Old 11-04-2014, 08:50 PM
  #9327
Originally Posted by Frank Root
I haven't run there myself, but I have been there and seen cars run. If I was racing stock there, I'd run RM.
My setup from OCRC for stock, or James Raschko's should be a good place to start.
Frank are you referring to your mid motor 17.5 setup for my RM setup? Will it be ok?
http://www.petitrc.com/setup/losi/setuptwentytwo2.0/222.0_FrankRoot_OCRC20140803/
liftmys10 is offline
Old 11-04-2014, 09:44 PM
  #9328
Dude....that sv3/4600kv combo will be awesome.
If I was you, I wouldn't get dissuaded.
For 110 bucks, you'll be getting some ridiculous power.
I have a sv3/5700 in my rc10 Worlds....the thing is ridiculous.
Doesn't even get hot n I'm geared on the high side....n that's without a fan.
Power, more than you can use......
The 4600...it's perfect...
You can even get a max amps 3s specifically made to fit the 22 n turn that thing into a straight up rocket.
I'm running mine with a 3s 4000kv motor n it's freakin awesome.
I had bought a sv3/5700 for the 22 but had trouble fitting the esc in there , due to the wires sticking up to far and hitting the body so I threw a 4000 kv motor in there I had laying around.....but, that 5700 will be going in there.
I've seen others with them (sv3 esc))in there so they will fit.
Like I said, you won't be disappointed if you go with that combo....That's a guarantee.
NickTheGreek is offline
Old 11-04-2014, 10:07 PM
  #9329
Jake S's Avatar
Jake S is offline
Old 11-04-2014, 10:12 PM
  #9330
That's the typical racer response
......n then you blow past em
