TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-03-2014, 10:46 AM
  #9256
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by liftmys10
I just bought a 22 2.0 and plan on doing MM setup. Where is everyone mounting their tekin RS esc? I'm running standard size savox servo with the MT4 airtronics receiver and shorty lipo.
Also what's the hot setup sheet for clay with medium to high grip? It's for SCVRC track in santa clarita.
I'd start with Maifield's setup - http://www.tlracing.com/ProdInfo/Fil..._Surf_City.pdf
Frank Root is offline
Old 11-03-2014, 11:40 AM
  #9257
Originally Posted by Frank Root
Thanks. Is that a blank setup sheet or is my browser acting up?
liftmys10 is offline
Old 11-03-2014, 11:44 AM
  #9258
TLRacing
Frank Root's Avatar
If you are trying to look on your phone, some mobile softwares (IOS for sure) don't have built in PDF readers. Adobe has a free PDF reader app that you'll need to view the details of the setup (which I have and works great).
Old 11-03-2014, 12:37 PM
  #9259
Yup I'm using my phone! I'll check from my house. Thanks for the help.
Old 11-03-2014, 01:19 PM
  #9260
Roger H's Avatar
Trader Rating: 24 (100%+)
Ive found once installing adobe on a iphone you still have to open in safari, click the image or scroll, and then click either open in adobe or ibooks.
These smart phones make me feel not so smart sometimes...
Roger H is offline
Old 11-03-2014, 04:41 PM
  #9261
A2Racing's Avatar
Hello,
I recently purchased a used 22 2.0 Buggy, I plan to race it indoors but it only has the rear motor set up. I was planning on purchasing a mid-motor kit but my search online has been unsuccessful for a single kit.
I was wondering if maybe some racers that are familiar with the buggy might help me out. If I order the following parts will I be able to convert my buggy to mid-motor?
TLR231014 - Battery Mounts Mid/Rear: 22/2.0/T/SCT
TLR2968 - Gear Case, Mid Motor: 22
Am I missing any parts? Or is anyone aware of a complete kit?
Thanks,
A2Racing is offline
Old 11-03-2014, 05:23 PM
  #9262
Jerm13's Avatar
Trader Rating: 36 (100%+)
Originally Posted by A2Racing
Hello,
Thanks,
Rear shock tower, rear camber block, inserts for the forward rear hinge pin holder, body, rear chassis guard/skid, waterfall ( which may come with the battery mounts, not sure) 2nd idle gear with bearings and associated hardware. There is something I missed, I know it.....
Shoot me a PM. I got everything for MM. Tried it and hated it. Will sell everything to convert including a good body for a pretty good price.
Jerm13 is offline
Old 11-03-2014, 07:41 PM
  #9263
wvrcracer's Avatar
Thanks. I do require some direction at times.
wvrcracer is offline
Old 11-03-2014, 10:00 PM
  #9264
Jokermayhem's Avatar
What are people doing if their running the Mayfield mid motor setup with the forth hole drilled in the tower? does the shock cap/body rub? Are you putting a spacer on the bottom shock outlet so the shock isn't so angled? thanks
Jokermayhem is offline
Old 11-03-2014, 10:08 PM
  #9265
gticlay's Avatar
Trader Rating: 14 (100%+)
I spaced the damper out on the a-arm with a 2mm spacer and shaved the tower as well. Hope that helps, will post pics if you need them.
gticlay is offline
Old 11-03-2014, 10:28 PM
  #9266
TLRacing
Frank Root's Avatar
+1
I've always run the 2mm spacer, and you'll need to clearance the tower a bit.
Old 11-03-2014, 11:40 PM
  #9267
Can you guys all please post pics of your mid motor wiring...trying to get ideas....
Old 11-04-2014, 01:29 AM
  #9268
I got a question about how and what the washer does on the rear axle??? I can't remember???
S.TRIPP77 is offline
Old 11-04-2014, 03:09 AM
  #9269
Errokk's Avatar
Changes the rear width of the buggy I believe.
Errokk is offline
Old 11-04-2014, 04:02 AM
  #9270
It changes dog bone plunge. Adding the spacer takes away rear grip by mechanicaly binding the dog bone up a little more wile the car squats under acceleration. This helps on real high bite tracks. Pretty much everyone runs with no spacer
fantomdude is offline
