TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-22-2014, 12:51 PM
  #9106
skeasor's Avatar
Is the transmission ratio of the losi 22 2.0 mid motor 2.43? I'm running a 13.5T and I'm trying to figure out my final drive ratio. I have it at 6.07 (70 spur, 28 pinon) right now which sounds about right...I hope
skeasor is offline
Old 10-22-2014, 03:17 PM
  #9107
seth556's Avatar
Trader Rating: 43 (100%+)
Raising the link will lower the roll center. Just remember raising/lowering the link does the opposite to roll center. While raising or lowering the arms will do the same to roll center.
seth556 is offline
Old 10-22-2014, 03:32 PM
  #9108
Jerm13's Avatar
Trader Rating: 36 (100%+)
Yes. 2.43 is the internal ratio. I had the same question and Frank Root verified that the ratio is the same for RM and MM.
You are spot on the book for your gear ratio with a 13.5 motor.
So your external ratio( spur and pinion) is 2.5 X 2.43 (internal tranny ratio)
Equals 6.075 ( your FDR).
So yes, your math is correct. Game on!
Jerm13 is offline
Old 10-22-2014, 03:53 PM
  #9109
skeasor's Avatar
Sweet! I knew I had to be pretty close but wasn't sure. Thanks for letting me know! It's always nice to have a starting point so I know when and where I can gear up or down.
thanks!
skeasor is offline
Old 10-22-2014, 05:32 PM
  #9110
SkipGear's Avatar
Originally Posted by jonbrown
Thanks for the reply,
I get what you mean about inherent slop, but do not understand why raising both ball studs the same amount would reduce it as the link has not changed lengths
It's not the distance between ball cups on the tie rod but the distance between the ball cup and the hinge pin that increases. Again, not a huge difference but it helps.
SkipGear is offline
Old 10-22-2014, 08:09 PM
  #9111
Bivens's Avatar
I tried the 0-hole on my MM car today....and bellcranks....those two changes made a big difference...much better rear traction combined with a smooth turn-in and great feel on the car....I'd been racing my RM car for quite some time now on our mid-bite or low-bite track....but I feel that my MM car will be seeing laps now...
Bivens is offline
Old 10-22-2014, 08:52 PM
  #9112
Bivens's Avatar
Question....
To make the MM conversion...do the SCT1.0 MM parts do it? (I currently have those in a bag while I run my old truck as RM...)
Bivens is offline
Old 10-23-2014, 04:18 AM
  #9113
Eggyolkeo's Avatar
Trader Rating: 11 (92%+)
Been experimenting with my carpet setup and tried a battery-way-forward config. Seemed to work well for the jumps but not well for steering.
Eggyolkeo is offline
Old 10-23-2014, 05:17 AM
  #9114
Errokk's Avatar
What was the steering issue you came across? Seems as if you'd have more then enough...
Errokk is offline
Old 10-23-2014, 05:39 AM
  #9115
skeasor's Avatar
What shock oil weight are you running?
skeasor is offline
Old 10-23-2014, 07:48 AM
  #9116
I usually MF tlr. But, I would like to thank frank and the boys for the -2.5 chassis
135mikefox is offline
Old 10-23-2014, 08:10 AM
  #9117
Just so everyone knows, this lighter weight -2.5 chassis should be available soon...
http://www.tlracing.com/Products/Def...odID=TLR331014
hacker07 is offline
Old 10-23-2014, 09:00 AM
  #9118
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
so is the chassis a mm deal only??? or is this a rear motor option also??
Matt M. is offline
Old 10-23-2014, 09:23 AM
  #9119
skeasor's Avatar
hmmm...good question. It doesn't specify RM or MM on the website though it looks like it's milled out a little differently.
skeasor is offline
Old 10-23-2014, 09:55 AM
  #9120
gticlay's Avatar
Trader Rating: 14 (100%+)
Exciting stuff Ryan! Is it a little thinner aluminum plate or is the chassis milled out more, or both? Also, will we need to dremel the side rails or are they re positioned somehow? I really like my -3mm chassis from Stiky Liks but it will be difficult to hold back from trying this one too...
gticlay is offline
