TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-21-2014, 09:27 PM
  #9091
RedBMaster's Avatar
Originally Posted by wiscR56
for those who are using the MIP Pucks system, are you upgrading the steel balls that come with it?
If so, what diff and thrust balls are you using? I would assume the TLR carbide diff balls (TLR2951) will work, but what about the thrust balls and washers in TLR2947
I used the MIP diff balls without issue, but I went with the avid caged carbide thrust. My diff is money!
RedBMaster is offline
Old 10-21-2014, 10:17 PM
  #9092
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Originally Posted by XXXDad
Thanks Glenn
Also the new 48 gram blocks are available with set squat degrees. I apologize for website I just haven't had time if you guys use Facebook it works best for me till I can get Website fixed. The new squat available in 1 deg, 2 deg, 2.5 deg, and 3 deg or any angle you guys want just takes a day to make special. Thanks
mbtoolmaker35 is offline
Old 10-21-2014, 11:14 PM
  #9093
Some one explain to me why use the old 1.0 front an rear arms??please??
S.TRIPP77 is offline
Old 10-22-2014, 04:24 AM
  #9094
muggy427's Avatar
They have more shock hole
muggy427 is offline
Old 10-22-2014, 04:58 AM
  #9095
jonbrown's Avatar
On some of the 22 2.0 setups on the TLR site I've noticed that that front camber link is raised 2mm or 3mm on the hub and on the bulkhead.
Daft question, why not run 0mm washers under both ballstuds?
jonbrown is offline
Old 10-22-2014, 05:09 AM
  #9096
SUPERLOOPER's Avatar
From my research by using the outer hole it will give more low speed steering or off power steering. Keep in mind that moving the shock out it will stiffen up the suspension so you might need to thin the oil.
Brian
SUPERLOOPER is offline
Old 10-22-2014, 06:39 AM
  #9097
Brian
And do they use the rear off the old buggy also??
Old 10-22-2014, 06:48 AM
  #9098
No, use the arm that came with the 2.0.
Old 10-22-2014, 07:52 AM
  #9099
muggy427's Avatar
Brian
Is that more for high bite tracks
muggy427 is offline
Old 10-22-2014, 10:29 AM
  #9100
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Wildcat1971
I use the Avid ceramic caged thrust. The pucks steel balls are not the best.
Or go with the guy that brought this size caged thrust bearing to the R/C market.
Casper-RC
V
Casper is offline
Old 10-22-2014, 10:35 AM
  #9101
Carranza76's Avatar
Casper-RC
V
Which by the way I have used for 3 rebuilds(the same one) in my 22 buggies.
Frank: any idea when the updated bell cranks will be in stock?
Carranza76 is offline
Old 10-22-2014, 10:40 AM
  #9102
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Casper-RC
V
lol, I was waiting for you to post. Took you long enough
Wildcat1971 is offline
Old 10-22-2014, 10:41 AM
  #9103
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
We should have more bell cranks in stock by the end of the month, or first week of Nov, and they will be updated.
Frank Root is offline
Old 10-22-2014, 10:56 AM
  #9104
SkipGear's Avatar
It still changes the roll center, just not as drastically. It also helps minimize slop.
Think of it as a 3 ft. pin with a 1/4" slop at each end vs. a 3" pin with a 1/4" slop at each end. The farther two points are apart, the less the inherent slop effects them.
SkipGear is offline
Old 10-22-2014, 12:02 PM
  #9105
jonbrown's Avatar
Thanks for the reply,
So am I right in thinking that if the inner and outer camber link ball studs are raised by the same amount it has a similar effect to handling as lengthening the camber link or just raising the bulkhead ball stud but is a smaller change to both?
I get what you mean about inherent slop, but do not understand why raising both ball studs the same amount would reduce it as the link has not changed lengths
jonbrown is offline
