TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-21-2014, 09:33 AM
  #9076
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by muggy427
Hey frank whats the part number for those turnbuckle kits is it just the 2 for steering??
There is no part number for just those parts, but you can get them in TLR234022
Originally Posted by Wildcat1971
What is the part number and price? What do you mean by product support?
Product Support = Customer Service for Products, it is a department at Horizon Hobby.
Frank Root is offline
Old 10-21-2014, 09:42 AM
  #9077
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
haha, I meant how do you order them for CS...
Wildcat1971 is offline
Old 10-21-2014, 10:20 AM
  #9078
TLRacing
Frank Root's Avatar
A phone call works best.
Old 10-21-2014, 11:31 AM
  #9079
Jake S's Avatar
Trader Rating: 67 (93%+)
frank... i had some 22-4 turnbuckles just in my box, but no extra hd cups, will the standard cups hold up fine on a 3.5mm turnbuckle?
Jake S is offline
Old 10-21-2014, 11:37 AM
  #9080
jake, the OD is bigger. you would have to drill out the std cups to 3.5mm. I am unsure if that is wise
Old 10-21-2014, 12:12 PM
  #9081
Bivens's Avatar
I just dialed up HH support line for surface vehicles...after describing my situation...the support staff indicated that they would be sending out my 3 sets of turnbuckles and rod ends.....no other questions asked...easy peezy...just like Frank said...Thank you TLR!
Bivens is offline
Old 10-21-2014, 04:24 PM
  #9082
Bivens's Avatar
For the bellcrank setup...does the offset TLR ball end go inboard or out by the spindle ball?
Bivens is offline
Old 10-21-2014, 04:28 PM
  #9083
TLRacing
Frank Root's Avatar
Inboard
Old 10-21-2014, 05:44 PM
  #9084
Bivens's Avatar
Thank you Frank. On the SCT....it already has HD turnbuckles....
Bivens is offline
Old 10-21-2014, 06:32 PM
  #9085
muggy427's Avatar
Ahh 22-4 parts. Thx frank for the help
muggy427 is offline
Old 10-21-2014, 06:37 PM
  #9086
wiscR56's Avatar
Default MIP Pucks- diff & thrust balls
for those who are using the MIP Pucks system, are you upgrading the steel balls that come with it?
If so, what diff and thrust balls are you using? I would assume the TLR carbide diff balls (TLR2951) will work, but what about the thrust balls and washers in TLR2947
wiscR56 is offline
Old 10-21-2014, 06:41 PM
  #9087
I use the Avid ceramic caged thrust. The pucks steel balls are not the best.
Old 10-21-2014, 06:50 PM
  #9088
Bivens's Avatar
A question about the 0-hole in the rear shock tower...
When I mount it up...the shock end rubs the rear of the tower just a bit....are you guys removing a little material from the tower "web" on the support strut....or shimming the shock mount rearward just a bit to make it clear without contact...??
(I found that a 22-4 shock tower already has 4-holes spaced properly...I used that as my drill jig...worked greatlll)
Bivens is offline
Old 10-21-2014, 07:30 PM
  #9089
gticlay's Avatar
Trader Rating: 14 (100%+)
I have shim plus shaved tower as needed. Pics if you need them.
gticlay is offline
Old 10-21-2014, 07:31 PM
  #9090
Bwadd2002's Avatar
Trader Rating: 15 (94%+)
Grind it down....
Bwadd2002 is offline
