TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-12-2014, 08:02 PM
  #8956
3D-Seth's Avatar
Trader Rating: 36 (100%+)
Originally Posted by skeasor
Does your car have more throw when you turn left than right? I'm running a 6070 servo too and notice that my slider will only turn right so far then just stops. I have my left and right throws both set at 120% but I always have more action to the left than to the right...I took everything apart and made sure that nothing was binding...it's driving me nuts
Originally Posted by Jerm13
Sounds like your servo arm is off a tooth or two. It should be slightly to one side when the wheels are straight. Cant remember which way.
I don't think you have a bind anywhere, it sounds like the servo is at is full limit in one direction...
I don't have issues getting full throw both ways. As Jerm said above, check to make sure the arm is centered properly, make sure the linkage is the right length (manual is only a starting point), turnbuckles are the same length, and don't be afraid to run the travel adjust above 120%. Run the travel adjust up until the linkages bind in both directions. If the numbers don't match (or within a couple percent of each other) linkages or servo center is off.
Seth
3D-Seth is offline
Old 10-12-2014, 08:04 PM
  #8957
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by GNS Racing 86
TLR guys..
I got the bell crank system yesterday and went to install it but the tie rods are too small for the cup ends, i have a 22 2.0 buggy, is there some mix up with the kits? or did i order the wrong kit? only seen 1 part number and said no mods necessary.
Quote" No Modification Required - The Bell Crank Steering System will install onto the TLR 22, 22 2.0, 22SCT, or 22SCT 2.0 without any modifications to the front bulkhead, servo mounts, or servo location "
also on the TLR site there was a note saying parts needed to complete, nothing was listed...
i had to rob the rods off my 22-4 to run the 22.0
please explain ...
We have now added the M3.5mm x 50mm turnbuckles to the next group of kits coming in (later this month). I have M3.5 x 50mm turnbuckles on their way to Product Support... BUT there are not here yet. I'll post again once they arrive, so please don't blow up product support yet.
Originally Posted by rbrownsr
Trying to change to 30 deg front kick. Can not find any shims to do that. What parts do I use?
It can't be done with a shim, you need the 30* pivot, made in plastic and/or aluminum.
Originally Posted by Dale.0
Root, on the new steering system, does adding washer on the rack add Ackerman? More washers = more steering or less steering?
Also I see on some of the new set ups going to 2deg of toe out. What will that do?
More shims = More ackermannn
More Ackermann = More aggressive off-center steering, and turning the wheels almosts acts like a mild front brakke.
I looked and looked and could not confirm this.....
When going from RM to MM, does the gearing change. Same motor/ ESC. Didn't even see a gearing chart in the MM section. Only the RM
Im running 24/78 for 10.5.
Thinking of trying the MM setup. Just have to find a body. Don't want to spend too much incase I don't like it. Anyone out there got a used all white or black in ok shape for MM they wouldn't mind getting rid of???
Gearing doesn't change, as the tranny ratio is still the same... BUT a MM car doesn't get the same airflow on the motor, so you may need to go down a tooth.
Frank Root is offline
Old 10-12-2014, 08:08 PM
  #8958
bru00z's Avatar
For those of us on the other side of the world will you be able to ship these turnbuckles to us as well when available?
bru00z is offline
Old 10-12-2014, 08:12 PM
  #8959
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Frank. Future 22 2.0 kits will have the 3.5mm turnbuckles or the bell crank conversions will have them?
Wildcat1971 is offline
Old 10-13-2014, 05:01 AM
  #8960
skeasor's Avatar
Seth
If I go by the length in the manual for the turnbuckles then I have some major toe out. I also remember when I first built mine I had 2 different sizes.
skeasor is offline
Old 10-13-2014, 05:33 AM
  #8961
TLRacing
Frank Root's Avatar
The manual images are not 1:1, you actually need to use calipers.
The kits are not being updated, but the Bellcrank sets are going to include 2x turnbuckles as stated in my last post.
Old 10-13-2014, 05:46 AM
  #8962
skeasor's Avatar
ahhh, that explains it Thanks!
skeasor is offline
Old 10-13-2014, 06:12 AM
  #8963
Ah ok. Well Poo. Mine will here today. Haha, I had to be bleeding edge. This is why I normally wait for new stuff
Old 10-13-2014, 06:23 AM
  #8964
SkipGear's Avatar
Frank,
Better make sure that is 2 turnbuckles and 2 HD rod ends. The 3.5mm turnbuckles won't do anybody any good without HD rod ends for the outside.
SkipGear is offline
Old 10-13-2014, 08:29 AM
  #8965
TLRacing
Frank Root's Avatar
Originally Posted by SkipGear
Frank,
Old 10-13-2014, 08:38 AM
  #8966
gticlay's Avatar
Trader Rating: 14 (100%+)
After some testing and a pretty great raceday, I'll say I think the bell cranks are worth it, even if you have to buy new turnbuckles and HD rod ends. Mine already had that but they are nice and smooth.
gticlay is offline
Old 10-13-2014, 09:53 AM
  #8967
Well, because today is a federal holiday.....I have to wait till tomorrow. lol. My kid TQd her class with the 2.0 car, but it pushes like a dump truck (RM on high bite). I was unable to run the standard clay slick because the car was all over the place. I am hoping the rack smooths out the steering and I can go back to clay tires on the car. She is really starting to get better....soon will be beating me
Old 10-13-2014, 10:03 AM
  #8968
skeasor's Avatar
Nothing better than a little father daughter competition I'm still trying to teach my son how to go around some orange cones in the backyard before I let him run on the track.
My 2.0 pushed like crazy with the RM configuration. I'm really hoping that with the MM it wont push as much but I wont be able to find out until Friday.
skeasor is offline
Old 10-13-2014, 10:31 AM
  #8969
Yeah, I did the same with with rocks in the street, lol. She hates MM. I tried to convert her to the B5, but even though the car looked better to me, it was too much steering for her and I had to listen to non stop, "I want my TLR car". What is comes down to is driver preference. And she prefers a 22 with under steer, lol.
Old 10-13-2014, 10:43 AM
  #8970
skeasor's Avatar
hah cones are a little more forgiving
skeasor is offline
