TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-07-2014, 08:26 AM
  #8836
kdeleon's Avatar
Lol. So I run the larger (HD) size turnbuckles on my car now. But I already purchased new smaller ones so that they would fit the new ball cup. If this is true, oh well a small waste of money.
kdeleon is offline
Old 10-07-2014, 10:40 AM
  #8837
Laurila's Avatar
Trader Rating: 21 (100%+)
Too funny. Why should I be surprised. Makes sense.
Laurila is offline
Old 10-07-2014, 11:49 AM
  #8838
splashn95's Avatar
Guys, can I get a quick suggestion for gearing. It's on a smaller/tight outdoor track and just need a general good starting point.
The 22 2.0 is running mid motor right now,
Gearing start points for a
17.5t d3.5 trinity
6.5t tekin gen 2
Both running on the tekin rs pro.
With the 17.5 I was thinking of just running the slipper eliminator, but need suggestions as I am fairly new with setups
splashn95 is offline
Old 10-07-2014, 12:01 PM
  #8839
Oh, I saw this coming. Seeing how the bell cranks come stock on the sct. And, it uses 3.5mm turnbuckles. Its ok, heres what you wanna do. Buy the lunsford heavy duty turnbuckle kit. Then you can run lunsford ball caps. Which have about half the slop of the stockers. If you don't believe me do a side by side test.
135mikefox is offline
Old 10-07-2014, 12:19 PM
  #8840
SkipGear's Avatar
That is my complaint with the Lunsford ball ends, too tight, not enough slop. They bind up the suspension.
Looks like Lunsford sells SuperDuty rods needed in pairs....
LNS35050 - 3.5 x 50mm Super Duty Tie Rods - $14.95. Not quite half the price of the full TLR set and it looks like out of stock right now.
I bought the TLR HD Ti set for my 22 so that both my 22 and 22-4 had the same HD ball cups. Fewer different parts to keep track of in the spare parts box was the primary reason. It had nothing to do with the performance of the original tie-rods.
SkipGear is offline
Old 10-07-2014, 12:23 PM
  #8841
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Last edited by Frank Root; 10-07-2014 at 05:03 PM. Reason: Bad info...too much cough medicine
Frank Root is offline
Old 10-07-2014, 01:04 PM
  #8842
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
My 22 2.0 turnbuckles are the same as my 1.0 was...Are you saying they should be bigger?
Wildcat1971 is offline
Old 10-07-2014, 01:20 PM
  #8843
Trader Rating: 54 (100%+)
Originally Posted by Frank Root
The ball cups do use the 3.5mm turnbuckles, which are included stock on the 22 2.0.
My new 2.0 has regular turnbuckles.
Same here man nothing HD on this car and I just bought it a few week ago.
GettinLapped is offline
Old 10-07-2014, 02:44 PM
  #8844
murco's Avatar
Same here, 3mm turnbuckles with kit. It makes it an expensive conversion if we need to get the TI turnbuckles aswell! If as Frank says the 3.5mm should have been with the 2.0 kit maybe TLR would be kind enough to supply us with the TI turnbuckles for free or just include the 3mm cups with the kits?
murco is offline
Old 10-07-2014, 03:12 PM
  #8845
SkipGear's Avatar
22 2.0's never came with 3.5mm tie rods.
http://www.tlracing.com/Products/Def...ProdID=TLR6018
http://www.tlracing.com/Products/Def...ProdID=TLR6077
As stated above, I bought them for the car so they would match the HD's that came with the 22-4.
SkipGear is offline
Old 10-07-2014, 03:16 PM
  #8846
MasiisaM's Avatar
thats disappointing....it's been marketed as the bell cranks have everything you will need out of the box.
MasiisaM is offline
Old 10-07-2014, 03:47 PM
  #8847
SkipGear's Avatar
Looking at a few photos, you may not need the offset ball cups on the buggy. It could be a difference between clearance in the truck and the buggy, the truck needing the offset cups.
SkipGear is offline
Old 10-07-2014, 03:48 PM
  #8848
gticlay's Avatar
Trader Rating: 14 (100%+)
Pretty minor issue. If the 22-4 ones will work, I have them kicking around for someone if you need them.
gticlay is offline
Old 10-07-2014, 04:13 PM
  #8849
Laurila's Avatar
When did that change? I have bought 2, 22 2.0's new and neither came with 3.5mm turnbuckles.
Laurila is offline
Old 10-07-2014, 04:22 PM
  #8850
Roger H's Avatar
Trader Rating: 24 (100%+)
I wouldnt get to excited guys. We all know TLR will make it right before it ships.
It could have been a typo by Frank also. Im sure he will make a official statement on here by tomorrow seeing as they frequent the board for product support.
Roger H is offline
