TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-03-2014, 05:38 PM
  #8761
JeepSpeed's Avatar
Nice paint jobs!
JeepSpeed is offline
Old 10-03-2014, 06:15 PM
  #8762
Trader Rating: 24 (100%+)
Some Yellow paint
redbaron is offline
Old 10-03-2014, 08:52 PM
  #8763
Jokermayhem's Avatar
Default Gearing question...help please
i am running rear motor with a Tekin Gen2 9.5T with a Tekin Gen2 speedo. I have the speedo mounted on the chassis under the shock tower and the battery right in front of it. I'm using the gearing suggested by Casper which is 78T spur with a 28T pinion. My buggy has been thermaling out at around 175/180 degrees and shutting down during the mains. I really like how the gearing feels... what would be a comprable gearing change with spur and pinion....but would cool down my speedo?
Jokermayhem is offline
Old 10-03-2014, 09:24 PM
  #8764
Back off a tooth or three on the pinion. Assuming nothing is binding, your buggy is telling you to gear up.
I run an 8.5 with a 24 or 25 pinion depending on the track and temperature.
CharlieHo is offline
Old 10-04-2014, 02:54 AM
  #8765
weavty1's Avatar
So are you temping the ESC at 175/180...? If so, are you temping at the base of the solder posts?
Regardless, that's pretty hot for an ESC and a 9.5 application.
I, too, would suggest going down a couple teeth, especially if its an indoor track. Also, are you running any additional mechanical timing or boost/turbo on the ESC? What about drag brake?
Your ESC should be maybe 140-160 after a full 8-10min race.. Use that as a reference point
weavty1 is offline
Old 10-04-2014, 03:03 AM
  #8766
Eggyolkeo's Avatar
Trader Rating: 11 (92%+)
I'm having trouble with ride height. The front is no prob, but the rear I can't get under 23mm. I'm wanting about 17mm (indoor carpet racing). I'm running standard red springs, and have the preload adjusters wound all the way out. I might go one step softer in the springs but don't think that's going to buy me 6mm.
Eggyolkeo is offline
Old 10-04-2014, 03:04 AM
  #8767
MasiisaM's Avatar
I use TY's set up from the Tekin website on my 9.5 and it works very very good for me and my track.
I float between a 25 and 24 depending on the size of my indoor tracks.
Set up
MasiisaM is offline
Old 10-04-2014, 04:27 AM
  #8768
skeasor's Avatar
Originally Posted by redbaron
Some Yellow paint
That looks sharp!
skeasor is offline
Old 10-04-2014, 04:28 AM
  #8769
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i run 78 24 with my tekin 9.5 and gen 2 rs....never had a problem....i run in blinky mode also...
Matt M. is offline
Old 10-04-2014, 04:29 AM
  #8770
skeasor's Avatar
Originally Posted by 3D-Seth
Not entirely yellow, but...
This looks really good too. I'm a horrible painter so mine will just be a single color
skeasor is offline
Old 10-04-2014, 05:42 AM
  #8771
DaSilva3525's Avatar
Originally Posted by skeasor
Thanks for the info! I'm surprised there is that much difference. Have you ran the gear diff with the 17.5?
To be honest I actually just bought the 22T the other week tore it all down last few days so I will be testing it out first time tomorrow. Rear motor set up to start even on carpet. I'll let you know how it goes
DaSilva3525 is offline
Old 10-04-2014, 05:47 AM
  #8772
Killer paint jobs! I paint single color as well just because I don't have a air brush to try and go to town on yet lol.
Old 10-04-2014, 05:49 AM
  #8773
Is anyone here running the exotek version 2 steering rack in their 2.0 buggies? If yes, opinions? I was mainly interested if the version 2 rack was changed to work with the 2.0 front geometry. Thanks!
solly is offline
Old 10-04-2014, 06:02 AM
  #8774
ThePanda's Avatar
Trader Rating: 68 (100%+)
Use internal droop limiters on the rear shocks. Then go back to what spring you feel works well.
ThePanda is offline
Old 10-04-2014, 06:03 AM
  #8775
Would like to know this as well. Been waiting on the TLR unit inpatiently lol..
