TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-02-2014, 11:13 AM
  #8731
Originally Posted by Headling
Any news on the bell crank steering release date?
We are all hoping they will be coming soon
hacker07 is offline
Old 10-02-2014, 01:57 PM
  #8732
Nemaris's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Jake S
im curious what front avid spring would compare to the kyosho gold front, and i guess in the same breath what would compare to the tlr yellow rear.
Purple is the closest at 3.63, the measured rate of the gold is 3.34 lb/in but feels stiffer like a 3.80. My theory on this is very similar to the way the light blue kyosho front spring for 1/8 scale is measured a certain rate but acts a different way because it has more coils. The big bore gold is the same way, more coils.
I think if Maifield, and Phend were sponsored by avid they would run purples. I've been told a lot of big manufacturers buy Kyosho springs direct though, which makes a lot of sense.
Nemaris is offline
Old 10-02-2014, 02:18 PM
  #8733
Thanks Ryan on the bell crank info
Headling is offline
Old 10-02-2014, 03:14 PM
  #8734
The closest would be the Avid reds. With what the kyo gold measures at and the avid red measures at, they are pretty close.
hacker07 is offline
Old 10-02-2014, 04:52 PM
  #8735
Jake S's Avatar
Trader Rating: 67 (93%+)
thanks ryan. i was kind of thinking of starting with red/yellow on 2wd, and purple/white on 4wd, based on looking at user created spring charts after not receiving a response from other members, thanks for confirming my thoughts.
Jake S is offline
Old 10-03-2014, 02:40 AM
  #8736
JeepSpeed's Avatar
I'm planning to do my first race with the buggy pretty soon. I have it set up as 17.5t RM. What battery would you guys recommend for novice/stock racing? Will be racing an indoor clay track. Amain has a Protek 4700/100c shorty on sale this month I was thinking about getting if its not overkill.
JeepSpeed is offline
Old 10-03-2014, 05:36 AM
  #8737
skeasor's Avatar
anywhere from 2.5mm-3mm of exposed shaft is where i have been running mine. 2.5mm seems better on lower bite, if traction is higher 3mm works well for me. i have never had good slipper feel setting it so the wheels come up off the table, i always just set it for on track feel.
Originally Posted by Cancun Tom
Thanks guys! I'll give that a shot.
skeasor is offline
Old 10-03-2014, 05:37 AM
  #8738
skeasor's Avatar
I'm running a venom 5000mah with 30C with my 17.5 and haven't had any problems.
skeasor is offline
Old 10-03-2014, 06:49 AM
  #8739
DaSilva3525's Avatar
Been lurking on here for awhile, even before I bought my 2.0 great thread & a lot of great info. Frank Root constantly on this board is pretty dam cool to see as well! #TLRtothefront
Any way I run on carpet only, been running a ball diff from the start everyone says I'm nuts but I've always been use to it. I'm in A main near the top half at my local track but I know I'm leaving a lot on the table through some of the tight turns. The only reason at the moment I haven't switched to a gear diff is all the stories of them leaking. I just can't deal with a dirty buggy & everything not being 110% lol I have issues that way. It's probably been discussed over & over but is it the outdrives that leak? Or just the main gasket?
I have been really enjoying this buggy & fine tuning it. Such a quality product with amazing support.
DaSilva3525 is offline
Old 10-03-2014, 07:04 AM
  #8740
Laurila's Avatar
Trader Rating: 21 (100%+)
For those of us with the exotek steering rack. The TLR bell crank ballcups and spindles are in stock at horizon FYI.
Laurila is offline
Old 10-03-2014, 07:48 AM
  #8741
MasiisaM's Avatar
I have been using the gear diff for a few months now..Tested and found 5K gave me the best turn in and forward bite on my mid-high bite clay surface.
I replaced the outdrive o-rings with Kyosho P-5 o-rings and haven't had an issue.
Kyosho P-5 o-rings
It has never leaked and works awesome.
MasiisaM is offline
Old 10-03-2014, 07:49 AM
  #8742
It have never leaked and works awesome.
Thank you very much
Old 10-03-2014, 08:51 AM
  #8743
chadg's Avatar
Trader Rating: 16 (100%+)
Kyosho P-5 o-rings
I'll second this. I put the Kyosho P-5's in my diff for the outdrives as well and it's been leak-free ever since.
chadg is offline
Old 10-03-2014, 09:13 AM
  #8744
skeasor's Avatar
I just rebuilt my ball diff today and was thinking about switching over to the gear diff. I may do that on the next build.
Is the gear diff heavier than the ball diff? I couldn't imagine that it would too much heavier.
skeasor is offline
Old 10-03-2014, 09:42 AM
  #8745
Probably very close, had them both in my hands but grams are grams. I will weigh them both when I do the swap and post back
