TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-30-2014, 04:14 PM
  #8716
Trader Rating: 23 (96%+)
I just picked up a 22 2.0. I have had it on the track a couple times and it has crazy torque steer. Every time I get on the gas hard it pulls right real bad. I have checked bearings and even left the tires on and removed the pinion and everything feels smooth no binding. I have noticed that I have a lot of play side to side with the diff. Not sure if normal or night. any help would be great because I canot find an issue that would cause that. Thanks
triplejracer is offline
Old 09-30-2014, 04:40 PM
  #8717
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
my diff has no side to side play
Wildcat1971 is offline
Old 09-30-2014, 04:50 PM
  #8718
Ok. Are the out drives from the original 22 cause that or are they the same
Old 09-30-2014, 04:51 PM
  #8719
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Wildcat1971
always re-grease your thrust when your doing a diff rebuild. yeah, I would rebuild the diff.
good look thanks for the feedback,,,,
now i have more diff balls do i need to grab more of the washers?
BlackStarRacing is offline
Old 09-30-2014, 04:55 PM
  #8720
you can flip the diff rings if you have not already. I dont think caspers thrust washers can be flipped. If you rings have not been flipped, you can flip them, replace the diff balls, grease caspers thrust and re assemble. break-in is key to the whole process.
Old 09-30-2014, 05:20 PM
  #8721
Ok kool, I'm going to use the same technics as Matt does in his youtube video... my biggest issue is always setting it up at the track....
What signs would you see if the diff was too loose and also if it is too tight....?
Old 09-30-2014, 05:27 PM
  #8722
too loose it barks, to tight it will feel gritty. Honestly, I can do it by feel now, so kinda hard to explain. just remember, the slipper should always slip before the diff.
Old 09-30-2014, 05:40 PM
  #8723
Hey Wild, thanks for the fast feedback much appreciated
Old 10-01-2014, 10:38 PM
  #8724
Jake S's Avatar
Trader Rating: 67 (93%+)
im curious what front avid spring would compare to the kyosho gold front, and i guess in the same breath what would compare to the tlr yellow rear.
Jake S is offline
Old 10-02-2014, 12:40 AM
  #8725
Any news on the bell crank steering release date?
Headling is offline
Old 10-02-2014, 05:00 AM
  #8726
MantisWorx's Avatar
Trader Rating: 28 (97%+)
RCShox garodisc are now available for the 22!!
MantisWorx is offline
Old 10-02-2014, 05:21 AM
  #8727
Awesome to hear.
Beaker151 is offline
Old 10-02-2014, 07:26 AM
  #8728
skeasor's Avatar
What is a good starting point for the slipper adjustment? How many turns from fully compressed?
skeasor is offline
Old 10-02-2014, 08:22 AM
  #8729
Cancun Tom's Avatar
Default How to set your slipper
Watch and try this
https://www.youtube.com/watch?v=YW7can6WjRw
Cancun Tom is offline
Old 10-02-2014, 11:10 AM
  #8730
Jake S's Avatar
anywhere from 2.5mm-3mm of exposed shaft is where i have been running mine. 2.5mm seems better on lower bite, if traction is higher 3mm works well for me. i have never had good slipper feel setting it so the wheels come up off the table, i always just set it for on track feel.
Jake S is offline
