TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-25-2014, 07:06 AM
  #8701
Trader Rating: 27 (100%+)
Thanks Seth!! Found a set. Gonna send other wrong set back and hopefully get a refund.
RandyJones is offline
Old 09-27-2014, 04:46 PM
  #8702
rraden's Avatar
Trader Rating: 259 (100%+)
Originally Posted by rraden
Does anyone know where you can get just the long set screw that is in the top shaft? I bent just the screw and don't want to buy a complete top shaft to fix it.
Bring this question around again. Anyone know where you can get just the set screw in the top shaft?
rraden is offline
Old 09-27-2014, 05:04 PM
  #8703
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Just get the Avid topshaft.
Wildcat1971 is offline
Old 09-28-2014, 04:43 AM
  #8704
RCW
Trader Rating: 29 (100%+)
Maybe I misunderstood, but I took it as he knew there were new topshafts available, but was trying to avoid buying one.
RCW is offline
Old 09-28-2014, 04:47 AM
  #8705
rraden's Avatar
Yes, all I need is the set screw. The top shaft itself is in perfect shape. Doesn't make sense to pitch it because of a set screw.
rraden is offline
Old 09-28-2014, 08:25 AM
  #8706
Trader Rating: 36 (100%+)
The setscrew is an M2.5 x 20, but good luck finding one. I searched quite a few places and the longest ones I could find were 12mm.
nitrousdave is offline
Old 09-28-2014, 11:14 AM
  #8707
Bivens's Avatar
You could screw in a long cap screw and cut the head off...if unable to find the set screw.
Bivens is offline
Old 09-28-2014, 06:21 PM
  #8708
ChrisWolfson's Avatar
You can buy another one and reuse the screw when you wear it out. You'll already have the replacement.
ChrisWolfson is offline
Old 09-28-2014, 08:08 PM
  #8709
gticlay's Avatar
Trader Rating: 14 (100%+)
I don't remember them being brittle, but anyone break a 1.0 front a-arm? I broke one in like 5 minutes of running my new car. Hopefully bad luck as I only have the 1 extra....
gticlay is offline
Old 09-28-2014, 08:44 PM
  #8710
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
like these?
http://www.amain.com/SAB-25x20mm-Cup...FYMF7Aod1DoA-A
sickpuppy1 is offline
Old 09-29-2014, 08:51 AM
  #8711
rraden's Avatar
Originally Posted by sickpuppy1
Wow, thanks! I searched Amain originally and got no hits. Exactly what I was looking for.
rraden is offline
Old 09-29-2014, 09:58 PM
  #8712
Default bodies??
Hey guys I am have 2 of the new TLR cab forward bodies painted. How do they fit or is there something about the way they fit that is different from the stock body??
S.TRIPP77 is offline
Old 09-30-2014, 06:12 AM
  #8713
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Quick Question: If you feel bumps when you turn the rear, would you say its time to rebuild the ball diff? Also i use the casper thrust setup is there anything with that i should look for? should i also re-apply black grease to it as well?
Thanks for all the feedback!
BlackStarRacing is offline
Old 09-30-2014, 06:16 AM
  #8714
always re-grease your thrust when your doing a diff rebuild. yeah, I would rebuild the diff.
Old 09-30-2014, 08:41 AM
  #8715
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
They fit well, shouldn't need to do anything special.
Frank Root is offline
