TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-16-2014, 05:42 AM
  #8626
Roger H's Avatar
Trader Rating: 24 (100%+)
The guys over at rocket rc are awesome. Best customer service ive probbly ever had. There even making me custom "orion" weights to drop in beside the battery. And on top of that willing to rush the order so i can have it all by the weekend.
Top knotch business.
Roger H is offline
Old 09-16-2014, 06:33 AM
  #8627
Does anyone make white ball cups that fit the turnbuckles/ball studs??
Also ordered a few parts directly from Exotek ....order said shipped but haven't received a tracking number in like a week....
How is their time frame as far as delivery goes??
NickTheGreek is offline
Old 09-16-2014, 06:34 AM
  #8628
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
jp
those are low frequency yellow rear springs correct?
Matt M. is offline
Old 09-16-2014, 09:33 AM
  #8629
JP.R's Avatar
Originally Posted by skeeler
Thanks, JP. I'll look that over.
I notice that this setup and a couple of other recent MM setups on TLR's site use the gold Kyosho spring in the front. Is that the big bore spring for the RB5, RB6, ZX-5, and ZX-6, part number KYOXGS003?
As far as I can find, this pring is a little stiffer than any of the TLR low-frequency springs, but similar to the green or blue regular 12-mm spring. Is that right?
The yes you have the correct part number. The Kyosho spring is 3.33 and our stiffest LF spring is the silver 3.18. So it is quite a bit stiffer than ours.
Originally Posted by Matt M.
jp
Yes LF Yellow.
JP.R is offline
Old 09-16-2014, 09:35 AM
  #8630
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I heard TLR might release some stiffer front LF springs for the higher MM bite tracks and for 4wd buggy.
Wildcat1971 is offline
Old 09-16-2014, 11:21 AM
  #8631
rcus3r's Avatar
When I ordered my steering rack some months ago, it came within couple of day of shipped confirmation. I am in CA, so it's just a few miles up the coast. Yes, they provide a shipping confirmation, but no tracking number.
Ordered some other parts over the weekend, and got a shipped confirmation yesterday.
rcus3r is offline
Old 09-16-2014, 11:52 AM
  #8632
elikeatts's Avatar
Originally Posted by elikeatts
Hey guys, I was just wondering what might be some good setup tips for running the mid motor 22 2.0 outdoors on a more loamy track? I have had pretty decent success with the mm car outdoors in the past, but was wondering what might make the car better/faster outdoors. I race mostly indoors where I live, so converting it to rear motor just for this one race would be time consuming and bothersome. I would like to try to just keep it mm and try to make that work everywhere. Thanks.
I guess no one really runs mm outdoors?
elikeatts is offline
Old 09-16-2014, 12:14 PM
  #8633
onadcr74's Avatar
Default Rear motor outdoor setup
Can someone send me in the direction of a good setup for the 22 2.0 rear motor outdoor, low to medium grip surface. I'm very sure that I can get it but was just wanting some reference just in case. I found one a few weeks ago, but I couldn't print it off as I was at work, lol! Someone said that there wasn't a whole lot of these setups around but this person put a link to someones setup, for this type of setup, but I can't find it again, of course!
onadcr74 is offline
Old 09-16-2014, 12:31 PM
  #8634
There's no setups that I've seen for loose outdoor dirt tracks. I've run rear motor all year and can't keep up with the B5s on a loose dirt track. I'm running 20 degree kick shim with 0 degree caster blocks and it drives in great but I can't get off the turns at all. I ran Frank Roots RM setup for a while but it had No steering at all. I had to use a ton of brake to swing it around which also killed my corner speed.
potatobed409 is offline
Old 09-16-2014, 12:34 PM
  #8635
Thanks.....I actually just received my order a lil while ago...
It was quick,,,,Thumbs up
Old 09-16-2014, 03:17 PM
  #8636
Tanis103's Avatar
I use this one from JR Mitch
TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-image.jpg
Tanis103 is offline
Old 09-16-2014, 03:44 PM
  #8637
MasiisaM's Avatar
Attachment 1232601
Just curious and a question for everyone...all being the same what difference would one see if you switch from the 1- a/b rear camber link to say the 2 unnamed holes on the hub below "d" in MM configuration. The angle would be wonky for sure...
An i wrong to think when talking about camber links...
Longer = more traction
Ball stud height - Shorter = more traction
MasiisaM is offline
Old 09-16-2014, 05:28 PM
  #8638
Camber Links/Roll Centres as discussed extensively are a big thing to adjust on any car, and they alter the car in lots of different ways.
In terms of what your asking what they do then your half right.
Longer Link = More Lateral Traction
Ball Stud Height - Taller = More Lateral Traction
The length of the camber link also has greater effect than that of the height of the inner ball stud.
Despite a longer link/taller ball stud having more lateral traction I only find that this is the case up to a point, which when the traction is lost it's generally much harder to catch the rear of the car. Because your also increasing the rear traction with a longer link/taller ball stud you do also lose steering, this is because the rear of the car pivots less around the front due to greater roll.
A shorter link/lower ball stud has less overall lateral traction, but greater steering response and the car's slide tends to be easier to control. A car with a shorter link/lower ball stud also tends to square up out of the corners a little better too.
Ashalak is offline
Old 09-16-2014, 05:42 PM
  #8639
MasiisaM's Avatar
thank you for the explanation...
in simple terms...longer = more traction...Taller = more traction but less than a longer link...its all relative and each have a cause and effect on balance ...Find the balance point of steering and traction in and out of the corner...is that correct?
MasiisaM is offline
Old 09-16-2014, 05:53 PM
  #8640
Slightly off-topic:
What are you guys doing to charge multiple 2S batteries with tube (female bullet) connectors in series or in parallel. I don't see many options for a ready-made cable. Do I need to just solder up my own serial or parallel cable to be able to do that?
skeeler is offline
