TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-12-2014, 01:34 PM
  #8596
Instead of the orion wts weights im going to use the battery tray weights by hobbypro. They are 23grams a weight and drop right into the 22 battery tray.
Beaker151 is offline
Old 09-12-2014, 04:38 PM
  #8597
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Talk to Mike at Rocket RC , best way is to email him so use the yahoo above .
The link is in my signature to his web store.... might be out of stock there ,but tell him Glenn Carlson sent you and ask nicely he should have some in hand. He also has the side pod Brass system.
Originally Posted by Roger H
Does anyone know the weight of the orion blocks that are being used?22g each Or a clean looking alternative? Check out his webpage then email for an order... don't forget who sent you.
Also, where can the brass antisquat blocks be found?
Im starting to put my 1/10 stuff back together after a brutal summer of 1/8 racing.
What seems to be the favored shock package for must with the current setups?
Ill be starting with the ryan/dakota setup and tweaking from there.
XXXDad is offline
Old 09-12-2014, 06:26 PM
  #8598
Trader Rating: 32 (100%+)
Mike is awesome! And does great work.
urluzn is offline
Old 09-13-2014, 06:48 AM
  #8599
I'm stopped in my build trying to decide if I want to continue with a RM build, or try MM.
Like I said, I run all outdoor, but, I have heard from many sources that the MM drives similar to my 22-4.
I often run 2wd and 4wd buggy back to back, and my 2wd times suffer because of it. Maybe if they drive somewhat similar, it might make the transition easier.
Decisions, decisions....
CharlieHo is offline
Old 09-13-2014, 07:32 AM
  #8600
XXXDad's Avatar
Truth is I struggle with my MM outdoors.I have all the trick parts... and setups.. I would recommend RM for outdoor.
XXXDad is offline
Old 09-13-2014, 08:16 AM
  #8601
Really depends on surface. I run outdoor mm and do very well.
urluzn is offline
Old 09-13-2014, 09:55 AM
  #8602
XXXDad's Avatar
Thumbs up set up
share your setup
XXXDad is offline
Old 09-13-2014, 10:26 AM
  #8603
Does anyone have their entire MM parts to sell or have a listing of part numbers of everything for MM? The previous owner of my buggy sold them.
sublimize23 is offline
Old 09-13-2014, 06:31 PM
  #8604
I just bought a new 2.0. I want my car to be just like Dustin Evan's car @ the Iowa Hobby Haven shootout.......If someone could point me int he right direction, track was outdoor and slick and his car still had more forward bite than a RM car with all the steering.
David Alberico is offline
Old 09-14-2014, 03:03 PM
  #8605
Does anyone know where to buy the cut tranny gears for stock racing?
I found them on cbcustomrc but only 3 gears for rear motor.
WalterMagnum is offline
Old 09-14-2014, 03:34 PM
  #8606
Taz_S's Avatar
Here the one for the MM tranny
http://www.shop.cbscustomrc.com/Losi...-Set-CBL22.htm
Taz_S is offline
Old 09-14-2014, 05:11 PM
  #8607
Trader Rating: 21 (100%+)
Only comes with 2 idlers and diff gear. Will just have a spare if you run rear motor.
Brian L is offline
Old 09-14-2014, 05:27 PM
  #8608
Ill get my buddies set up, him and dustin are good friends and im sure he is running his same set up. It may take me a few days but I'll get a hold of it for you. You are going to need the rocket-rc anti-squat block, and i beleive he is running the TLR side pod weights. There is one problem that you will have and that is the TLR bellcranks are not available yet and that is where a good amount of his steering is coming from. It has a drastic difference in steering consistency.
Skeeter36 is offline
Old 09-14-2014, 06:14 PM
  #8609
rcus3r's Avatar
Are there any other options for slipper eliminator, other than Exotek. Don't mind buying the Exotek part, but not crazy about paying $15 for a special spur.
I guess I could drill out the Losi spur to fit over the Exotek spur mount, but if there are other options, please let me know.
Thanks.
rcus3r is offline
Old 09-14-2014, 06:41 PM
  #8610
XXXDad's Avatar
Exclamation Under $6
Get two>http://www.amain.com/Search?cID=&s=KIM150
Thanks.
XXXDad is offline
