TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-05-2014, 07:54 PM
  #8551
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up
Like this>
Originally Posted by BlackStarRacing
hey guys outside of weight distribution is there any benefit when running mid motor to run the esc up close on the waterfall and push the battery forward rather than placing the esc behind the servo and running the battery back?
XXXDad is offline
Old 09-06-2014, 07:38 AM
  #8552
rob martin's Avatar
Trader Rating: 66 (100%+)
My freshly painted silencer
rob martin is offline
Old 09-06-2014, 10:16 AM
  #8553
dmatter's Avatar
Looks good Rob!
dmatter is offline
Old 09-06-2014, 11:22 AM
  #8554
XXXDad's Avatar
Always lookin Fresh Rob
XXXDad is offline
Old 09-06-2014, 02:29 PM
  #8555
rob martin's Avatar
Thumbs up
Originally Posted by dmatter
Looks good Rob!
Thanks fellas!
Old 09-08-2014, 08:24 AM
  #8556
jeffyrc's Avatar
Only asking in here cause I know it gets attention from the top level TLR guys. Trying to officially reach Mr. Eduardo Cruz, where can I find his official contact info? Thanks in advance guys.
jeffyrc is offline
Old 09-08-2014, 09:00 AM
  #8557
Braxamus's Avatar
If someone is going to start racing a buggy, and already has some 2WD and 4WD SCT exp. what would be best way to set it up mid. or rear motor configuration? On a track with good traction indoors.
Braxamus is offline
Old 09-08-2014, 12:53 PM
  #8558
Casper's Avatar
Trader Rating: 34 (100%+)
I fell RM is more consistant and easier to drive. MM is tyically faster but more senstive to track changes. If your track has high grip go with MM with the track is med to low or grip level varies greatly I would go RM until you get the hang of driving a buggy. This is just my opinion.
Casper is offline
Old 09-08-2014, 03:15 PM
  #8559
Does anyone here has access to a CNC machine to make some parts I designed for the TLR 22? A 3D printer could be nice too. Thanks.
30Tooth is offline
Old 09-08-2014, 03:21 PM
  #8560
yes.....
send me the .stl file
Jason Snyder is offline
Old 09-08-2014, 04:00 PM
  #8561
Originally Posted by Jason Snyder
yes.....
Thank you sir, you have PM.
30Tooth is offline
Old 09-08-2014, 06:41 PM
  #8562
Nemaris's Avatar
Trader Rating: 18 (100%+)
I have a similar question as what was asked earlier about mounting the ESC to the chassis in front of the battery with no waterfall. I have been able to set my car up this way only using the v1 Exotek bellcrank steering (full sized servo). With an Orion just in front of the battery which is all the way up against the motor. So for my question, will having the car set up this way put too much weight bias to the front of the car? I noticed I had to add as much as 30g over the rear transmission to get it feeling right.
Other than having to add weight it seemed fine, but this put me at a disadvantage in 17.5 and 13.5 classes since my car was now heavier. I never really ran mid motor with the normal mid motor mount that allows you to put the esc on top of the battery strap. Will running it this traditional way be too different than this? I noticed a lot of top guys get by just fine running it the way described in the manual, just with added weight. I just don't understand the difference besides changed weight bias, and center of gravity.
Nemaris is offline
Old 09-08-2014, 08:47 PM
  #8563
Trader Rating: 19 (100%+)
Nemaris, I run my TLR buggy without the motor brace in it. I have the TLR 50g rear weight on my diff housing. It comes with 4g and 5g added weights. That screws into the bottom of the weight. Like an upside down T. I put the 4g weights. In front of the rear A-arms. I use a long screw with a locking nut on top of the weight.
I just purchased some side pods brass weights from Rocket RC.
b4wires is offline
Old 09-09-2014, 07:12 AM
  #8564
XXXDad's Avatar
When running Mid Motor this is what you need>
http://nebula.wsimg.com/c140ec8bb3db...&alloworigin=1
The Problem with running Stock with MM car is that when running MM you need to add weight. That's why most all run Stock in Rear Motor Configuration.
I run Mod in MM and Stock 17.5 Blinky in RM.
Why you say: Lighter car. In RM you have the Traction advantage so using a slipper eliminator and cut gears and ceramic bearings gives you the edge. Along with your $200+ ESC and $150 +motor $100+ LiPo, and all the titanium parts $100+. Stock aint Stock anymore.
XXXDad is offline
Old 09-09-2014, 08:00 AM
  #8565
Braxamus's Avatar
Running a med to high grip track, say a 13.5 to 17.5 motor in rear mount and if running the std. battery (long) would any weight be required?
Braxamus is offline
